Tube Maker
george daniel
Kinda long video,guy makes tubes.
http://dailymotion.alice.it/video/x3wrzo_fabrication-dune-lampe-triode_tech
I must be a geek. I watched the whole thing.
This video helps you understand the failure rate of tubes. I've read that all tubes are at least partially hand-made and the rejection rate at the factory is as high as 50%.
I also got a sense of why some of the larger tubes cost so much. Geez.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Nice video...surprised he touches the bare porous metal with his greasy bare fingers ? No mater how much he heats/trys to clean that metal before placing it in the vacuum atmosphere ...when the metal heats up under vacuum it is going to outgas and cause problems for the finished tube.
You would have to glass bead blast and do an ultrsonic chemical clean to get the finger oils out/off before placing the metal in the vacuum enviroment like that. No wonder being hand made and having failure rates so high go hand in hand .
Look up outgassing in a vacuum...some pretty good reading for "geeks" that made it through the whole video
Our hot cathode ionization guages at work are built pretty close to audio type tubes ( http://en.wikipedia.org/wiki/Hot_filament_ionization_gauge ) ...fun stuff. The first rule of Fight Club is you don't talk about Fight Club -
shadowofnight wrote: »Look up outgassing in a vacuum...some pretty good reading for "geeks" that made it through the whole video
Well, maybe I'm not such a geek after all.:pHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I too watched the whole video. It had me captivated. I wish it was in English.
There's some real hack procedures there. I worked in manufacturing
automation many decades ago, and most of that is very crude.
The problem is, tube making is done is cheap labor areas of the world, and
investing in equipment doesn't make sense when people are so cheap.
The consistency of the tube quality goes all over the place when done
like that. This is why modern tubes don't compare with NOS.
But then again, what do I know?:D"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Awesome! Was that Jesse?
