Question about polkaudio speakers
Tim2121
Tim2121 Posts: 7
edited January 2008 in Speakers
HI
I am new to this forum. I currently have the YAMAHA HT5840 REceiver (85w per channel) and Sony floorstanding speakers. I would like to upgrade to the Polk Monitor 50 or the RTI8 model speakers. Is it okay to use my current receiver or do i have to upgrade to a new receiver? I really dont want to buy another receiver since i just bought this one for less than a year. Thanks
Post edited by Tim2121 on
  • george daniel
    george daniel Posts: 12,096
    edited January 2008
    I think that you will be fine, just don't get carried away with the volume control and overdrive it to the point where you cause the amp to clip and causes you to smoke the tweeters. See how you like it and then go from there if the bug bites you to upgrade, most of all,don't get too over analytical ,and just enjoy your system,,have fun,enjoy and welcome to Club Polk.:)
  • Tim2121
    Tim2121 Posts: 7
    edited January 2008
    I am afraid that the rti8's are too strong for the receiver. Should i downgrade it to a pair of RTI6's instead? My receiver only has 85w per channel. Thanks
    RTI6 -125w
    RTI8- 250w
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    Look more at the efficiency of the speakers vs the max power. A speaker rated at 90db watt will actually put out more sound than a smaller speaker that puts out 88db per watt.
    Welcome to Club Polk
    Also try to go RTI if budget allows. You will save in the long run.
    Ben
    Ben
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2008
    Welcome to CP! You will be fine with the RTI 8's.
