Subwoofer for RTi12
Hi Polks,
I am a newbie.. I have puchased Rti12 for front with CsiA6 and FxiA6 series. I got denon AVR-987 receiver in the matrix. Just wanted help with subwoofer. I got Polk DS Pro 600 from Frys but some what not satisfied. Please suggest suitable sub. Will PS505 is the best or Velodyne 10" DSL-3750 will work? or suggest any other good combination for RTi12
Vk
Vk
Post edited by vkpolk on
Since the Rti12 could handle 2 channel music on there own, is the sub for HT use?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
The dsw pro should kick ****,are you sure you set it up right in the receiver and the sub?
Crossover settings?Whats the other gear your running?HT SYSTEM-
lsi 9's -
Welcome to Club Polk. Do a lot of reading on your Denon. Use the LFE out for the sub setup, and not the speaker wire setup. Sometimes setting the sub out to LFE+ L/R is the way to fly for music, and HT.
Ben -
I have Rti12s and Im using 2 of these:
http://www.svsound.com/products-sub-box-plus2.cfm
You can get by on using one but Im a bass head. Of course you should check setup as others mentioned. But if you feel that its still not performing up to your standards, take it back and go with the SVS, Epik or Elemental Designs product.Shoot the jumper.....................BALLIN.............!!!!!
No one knows for sure if the DSW are decently comparable to the entry Hsu/eD yet...?
