Outdoor XM Antena?
DollarDave
DollarDave Posts: 2,575
edited January 2008 in Electronics
I scored an Polk XM tuner recently and just subscibed. Well, I was indeed born last night, and I do not have a southern exposure anywhere close to my home office.
Does anyone have some suggestions for an outdoor antena? I have a Directv dish and could mount something on or near it?
  • MusikSource
    MusikSource Posts: 44
    edited January 2008
    I had the same problem and bought a marine antenna and mounted it on my roof. I bought mine off of ebay.
    Right or Wrong Just Offering My Oppinion!!!
    Panasonic PT-AE1000U 1080p Projector
    LG-BH200 Super Blu - Ray/HD Combo
    Onkyo TX-SR805
    2 Pair Polk Rti-8 Front & Rear
    Polk Fxi A4
    Polk CSi A6 Center
    Sub’s Abstract ASXPRO10
    Onkyo SKW-530
  • DollarDave
    edited January 2008
    Did you have to extend that antena cord, or did you convert it to the coaxial cable (RG6 is it?) and then back agian?
  • dorokusai
    dorokusai Posts: 25,661
    edited January 2008
    You can buy an 50ft. extension cable for the stock antenna.
  • MusikSource
    edited January 2008
    I Bought an extension cable?
    Onkyo TX-SR805
    Polk Fxi A4
    Polk CSi A6 Center
    Onkyo SKW-530
  • DollarDave
    edited January 2008
    dorokusai wrote: »
    I was hoping you had converted to coax because that is what I have pre-wired in my office and I have a 20 foot ceiling in there. I suspect that the antena cord is too fragile to pull through the walls.
  • Gadabout
    Gadabout Posts: 1,072
    edited January 2008
    Terk offers an outdoor antenna that runs RG6 (coax).
    http://www.dl-electronics.com/store/item.php?sku=TERXM6
    Better description of the antenna here...
    http://www.xm-radio-satellite.com/index.asp?PageAction=VIEWPROD&ProdID=2004
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • sucks2beme
    sucks2beme Posts: 5,703
    edited January 2008
    I pointed mine out a North window. It worked fine. In a lot of larger cities, XM
    has ground repeaters. That means just try moving around the antenna.
    You might be surprized.
  • steveinaz
    steveinaz Posts: 19,547
    edited January 2008
    DaveMuell wrote: »
    Word is that if you modify the antenna cable in any way, it'll quit working--but I don't know the particulars. You'd be better off with the XM extension.
