Room Treatment-ATS Panels
I-SIG
Well, my color swatches for the ATS panels have shipped. Gonna do some room treatments as part of my painting and decorating in the living and dining areas.
Wes
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
I will be interested in what they are like. I think room treatments are the next on the list for me also. I will diy them most likely. I googled ats and got nothing. What do they cost per set?Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
Go GIK or go home.
I've got a few of them myself (3-2x2x4" & 1-2x4x4") along with panels from other manuf. Great stuff, well built & look great. You should notice a difference in your room sound for the better. Once you see & hear how well they work you need to keep going. Remember, a well treated room is the best upgrade you can do."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
pearsall001 wrote: »I've got a few of them myself (3-2x2x4" & 1-2x4x4") along with panels from other manuf. Great stuff, well built & look great. You should notice a difference in your room sound for the better. Once you see & hear how well they work you need to keep going. Remember, a well treated room is the best upgrade you can do.
BIG +1 -
ATS Panels
Try the above.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
This thread helped me out when I went the acoustic treatment route:
http://www.polkaudio.com/forums/showthread.php?t=51863&highlight=GIK+Room+Treatment
It has some good links to other useful info. as well. -
ATS may be great, but they don't seem to post any complete testing results. Take a look at the testing.
ATS
http://www.atsacoustics.com/item--ATS-Acoustic-Panel-24x24x4--1007.html
GIK
http://www.gikacoustics.com/absorption.html
GIK shows complete testing results. ATS doesn't. For a few extra bucks, you may be getting quite a better product. Just my 2 cents. I by no means am saying ATS is bad. I am just saying you may be able to do better. Options are good.
http://www.averagejoeavreviews.com/reviews/traps/0001gikacoustics/review.htm
http://www.audioholics.com/reviews/acoustics/gik-acoustics-244-absorption-panel-review/gik-acoustics-panels-overview-and-installation -
ATS & GIK are both excellent products. You can't go wrong with either. At the time I made my purchase ATS had a much better fabric selection than GIK. That in itself was the deciding factor. I've since purchased a GIK Monster bass trap (2x4x6") & also Echo Buster products & a few Aurelex products. My next move is going to be these guys: http://www.realtraps.com/diffusor.htm.
It's an accumulative effect, the more you do, the sound just keeps on getting better & better. And, don't worry, it's almost impossible to overtreat a room."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
I love my Real Traps.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
wingnut4772 wrote: »I love my Real Traps.
Which one's do you have Darla? Ethan has a pretty good line up going."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
The Bass traps. I don't remember the models but the pics are in my link under the HT section.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
SolidSqual wrote: »ATS may be great, but they don't seem to post any complete testing results. Take a look at the testing.
ATS
GIK
Thanks for the GIK info. Good stuff, but almost 50% more per equivalent panel adds up quickly, plus there are 2' x 2' options available at ATS that wouldn't be custom.
The Real Trap mentioned by Phil and Darla are nice too, but even more pricey.
I'm gonna stick with ATS for now, but I'm very interested in the GIK Tri-Traps and Diffusers in the future. I think the Diffusers would be pretty neat and effective on the ceiling!
The ATS panels should be just as effective as the GIK or Real Traps of the same thickness and they have lots of colour options.Testing
Testing
Testing
