A PR problem....
geoff727
Looking at the crossover schematic for my -1C's (et. al.), there's an inductor between the "-" sides of the stereo and dimensional arrays. On either side of that inductor are two little boxes, labeled P and R. Can someone tell me what P and R mean?
Wait a minute, I think I'm having a revelation here, and my thought process is Perfectly Reasonable. If I solder the Passive Radiator there, it ought to turn one Perfect Revolution, then change to Pink and Red, and harden into Padouk Rosewood solid enough to Push Rivets, right? Something like that?
No, seriously....I don't get how only one interconnect wire can cause both speakers to radiate a signal that's 180 degrees out of phase with the opposite speaker to attempt to cancel crosstalk. I keep trying to play this out in my mind from the schematic, but it just ain't happening. Does someone have a layman's explanation for my limited electrical knowledge? I wish I had known a little more before doing the crossover upgrade, but what's done is done.
Thanks,
Geoff
Thanks,
Geoff
Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS-II (modded)
Infinity RS-IIIa (modded)
Infinity RS 2.5 x 2
Magnepan 1.6QR (modded)
System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Post edited by geoff727 on
Maybe that is were they connect on the Crossover board? Just a guess.
I thought you had a problem with your Passive Radiator. -
Could be. I don't know. The ends of that big inductor solder on the PCB just like all the other connections.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
