I need a FET for PSW 120 subwoofer
Don Piano
I need to know wher I can find a FET for PSW 120 subwoofer # F9520N.
Any help will welcome.
Thank you.
Thank you.
Post edited by Don Piano on
Is that the actual number on the transistor?If it happens to be an IRF9520N Then Digi Key will have them.http://www.digikey.com/I need to know wher I can find a FET for PSW 120 subwoofer # F9520N.
Thank you.Testing
Testing
Testing -
A quick search shows that a IRF9520N (most likely what it is) is a P-channel mosfet. The case is a TO-220, or about 3/8" square.
A blown transistor can often be a sign of another faulty piece. Those transistors are freakin workhorses. -
Thank yuo my friend but not, Technician say that this is an especific part, it most to be ecxactly as the original (F9520N9)
Greetings from Costa Rica.
