PSW 650 Placement
botany
Hello, I hope that I get some feedback on the placement of my 650 Sub.
As you all know the PSW 650 has 2 ten inch drivers. Do I place one of the drivers to the wall and the other driver into the room?
Or Do place the drivers running the same way the walls run, that is; the back of the sub to the wall. (the hook up's to the wall)?
I know a lame question, but I am learning allot.
Botany
Botany
Post edited by botany on
I have mine on the side of the room with the back against the wall, so that one sub is firing foward and one backwards. You may want to experiment with different positions since every room is different.
i use two psw-650 as my main channels with speaker level connections to subs then to my main speakers with are rt-7. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces.
