bi-amping the rti a9
carversound
carversound Posts: 44
I never bi-amped before.Have carver m1.5t for bottom and a carver m4.0t for top. Do I need crossovers or are the ones in speaker ok. And if I need crossovers where and what ones?
Post edited by carversound on
    treitz3 Posts: 20,069
    edited January 2008
    Hi Carversound, welcome to the forum. Admittedly, I'm not familiar with your particular speaker, but if you have two sets of binding posts on each speaker, the internal x-over will work perfectly fine. Enjoy.
  • carversound
    edited January 2008
    thanks treitz3
  • ShinAce
    ShinAce Posts: 1,194
    edited January 2008
    The ideal would be to bypass the internal crossover of the speaker and have an active crossover to feed a signal to the amps. Consider it down the road as a possible upgrade.
