Matched a Carver M-1.0t to new RTi10's
djc9
djc9 Posts: 37
edited January 2008 in Electronics
Picked up used cheap off craigslist.
Hooked up via the preouts on my Yamaha HTR-6090. So far after playing a few cd's I'm very happy with my first amp purchase. Haven't experienced the Carver "thump" when turning off yet.
Thanks all the regulars, this forum has been the best resource since I bought my first pair of R15's a year ago.
Now all I need is another amp for my CSi3 and some FXi5's? I thought I was done after the RTi10's but craigslist keeps pulling me back in.
Post edited by djc9 on
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
    Congrats on the Carver. Do me a favor and get a Csi5 instead of the 3.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited January 2008
    Sounds like a good time. Rock on.
  • djc9
    djc9 Posts: 37
    edited January 2008
    daboyz wrote: »
    No doubt I was looking for a 5 but couldn't help myself when a 3 came up for sale locally. It's definitely on the horizon.
  • djc9
    djc9 Posts: 37
    edited January 2008
    I'm doing some research and can't find the answer to whether the Adcom GFA535 will operate in bridged mode. There's no documentation of bridged mono specs for the GFA535, anyone know whether that's the final answer?
    Alternatively, would bi-amping my CSi3 with the GFA535 be a desirable option? I'm trying to stay $200 or less for the center channel amp so I'm also looking at the Audiosource 5.3 monoblock, running $200 at amazon shipped which does 150wpc @ 8 ohms. Audiosource's stereo offerings (One/Two/Three/100/200) are some others I'm looking at in bridged mode.
    Thanks in advance.
  • jwhitakr
    jwhitakr Posts: 568
    edited January 2008
    I've never read any specs that say the GFA535 can be operated in bridged mode, which is why I ruled it out of my search for a center channel amp. I would go to Adcom's website and check the owners manual ... I'm sure they have it available online.
    I ended up getting an Audiosource 100 and that's what I'm currently using for my center channel. I'm planning to upgrade very soon, though, since I just got a used Parasound amp for the L/R channels and want my center amp to also be a Parasound.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
    heiney9 Posts: 25,604
    edited January 2008
    djc9 wrote: »
    Thanks in advance.
    The only Adcom that can be run in bridged mode is the GFA 555 and 555II. Perhaps there are some multi channel Adcom's that will do 1 channel as well but I don't recall the exact model #'s off the top of my head.
    Audiosource amps are made by ATI (if I remember correctly) and certainly a suitable solution. I'd choose an Adcom over an Audiosource any day but it seems the Audiosource has the configuration you are looking for.
    Good luck and Welcome
  • djc9
    djc9 Posts: 37
    edited January 2008
    It looks like the Adcom 5002 (175wpc) and 6002 (200wpc) can be run in bridged mode and I'm seeing some of these locally for sale. Would also make a solid future surround channel amp I believe. I hear nothing but good things about the GFA535 but the lack of versatility with the absence of a bridged mode keeps me away.
    Thanks.
  • djc9
    djc9 Posts: 37
    edited January 2008
    Got a hit on an Audiosource Amp3 that I will pick up today that will run 400wpc in bridged mode (150wpc stereo).
    My CSi3 should be able to handle the bridged mode wattage correct? It's rated for 180wpc max which doesn't mean much I know but since I'm still very much an amp novice I wanted to make sure.
    edited January 2008
    Should be fine
    edited January 2008
    Waisted wattage on the center.No need to throw 400 watts at it.Don't get the fascination with bridgeing.You only add hum and noise in most cases,and shorten the amps life expectancy.Buy a decent 3 channel amp for the front or save up some coin for a 5 channel amp.Just my.02.
