Frequency of THX intro
burdette
burdette Posts: 1,194
edited November 2002 in Music & Movies
There is a THX speaker test on some DVDs... it plays a tone through each of the speakers in turn (Toy Story has it). Does anyone know the frequency of the subwoofer tone used in this test??
I can hear and feel the tone through my Monitor 7Cs, and was just wondering what frequency I was getting.
Thanks.
Post edited by burdette on
  • HBombToo
    HBombToo Posts: 5,256
    Are you referring to the Pink Noise measurement?
    ***WAREMTAE***
  • HBombToo
    I found this on the Net. should help clear things up a bit.
    The characteristics of pink noise
    For the purposes of this discussion, "power" means the average power or energy contained in a signal over a long period of time.
    White noise has the same distribution of power for all frequencies, so there is the same amount of power between 0 and 500 Hz, 500 and 1,000 Hz or 20,000 and 20,500 Hz.
    Pink noise has the same distribution of power for each octave, so the power between 0.5 Hz and 1 Hz is the same as between 5,000 Hz and 10,000 Hz.
    Since power is proportional to amplitude squared, the energy per Hz will decline at higher frequencies at the rate of about -3dB per octave. To be absolutely precise, the rolloff should be -10dB/decade, which is about 3.0102999 dB/octave.
    HBomb
    ***WAREMTAE***
  • Dr. Spec
    Dr. Spec Posts: 3,780
    The THX test tone generator subwoofer tone is centered at about 40 Hz, but contains some harmonics above and low that.
    Doc
    SVS
