CSi25 ?
hydrostream
Is it ok to use a 4 ohm center with all
my others being 8 ohms?
jerry
jerry
Main- GTP-500II,GDC-600,GFA-555II and energy C-500s
Basement-Audiosource pre/tuner,GFA-545,Onkyo
DX-1400 and RTI10s
Garage-GTP-450,onkyo M-282 and R50s with RTi55
drivers and X-overs.
My baby 18' V-king Mod VP with a merc 2.4 BP.
KTM 620 Supermoto
DX-1400 and RTI10s
KTM 620 Supermoto
Post edited by hydrostream on
The CSi25 will do both just fine. I have one (retired). My original system was RTi6, CSi25, and R15's.
Just wondering in my setup menu
it asks what omh speakers i'm
using. 4ohm,8 or 16
And i think i can only choose 1.
jerryMain- GTP-500II,GDC-600,GFA-555II and energy C-500s
DX-1400 and RTI10s
KTM 620 Supermoto -
Select 8 ohms. I have a Yamaha receiver and at the time no external amps were connected. I had no issues running 8 ohms with the CSi25 along with the RTi6 and R15's.
Search around on the forum or contact customer service. This has been covered before. -
I found one for sale local for $50.00
Thanks for the help i think i will
give it a try.
DX-1400 and RTI10s
KTM 620 Supermoto -
I'm sure it will be a step up from
my R150 as a center.
DX-1400 and RTI10s
KTM 620 Supermoto -
I ran a CSi25 with R50s and R150s on an Onkyo TX-SR605. As long as you set them all to small you should be okay.
