Need info on older model Polk Sub (PICS)
00RAM
00RAM Posts: 3
edited January 2008 in Car Audio & Electronics
I need some help with this older model Polk sub. I think it was called an EX or DX.. Does anyone know where I could get the specs for this sub, it is a 10" single 4 ohm woofer. I need to know the power handling and ideal sealed box size.
Here's a couple of pictures:
Post edited by 00RAM on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited January 2008
  • 00RAM
    00RAM Posts: 3
    edited January 2008
    Thanks for the info. My amp will do 400x1 RMS at 4 ohms. If I keep the gains turned down, do you think it would blow the 10" sub?
  • Jstas
    Jstas Posts: 14,999
    edited January 2008
    It's an EX10 for sure.
    And 400 watts RMS x 1 on a sub that handles 150 watts RMS is not a very good idea IMO. You can turn those gains all the way down and it will still be overpowering that sub by at least 50 watts.
    That sub is old and it's dusty so it's probably been sitting around a while. That amp will probably end up chewing that sub up. You're better off getting a small stereo amp that is bridgeable and run it off of that with a low-pass filter on it.
    Expert Moron Extraordinaire
