175 watts into Rti6
CAvolleyballguy
If I hook up an adcom 7700 with 175 wpc into my Rti6s will it blow them as they are only rated for 125? I do not listen to stuff very loud but if I turn them up I dont want to blow 4 speakers either???
I will be using this for HT and stereo so they will get 2 channels and multi use.
Rti10 front, csi5, Rti6 surrounds, PSW505, B&K200.7s2, Onkyo705.
Post edited by CAvolleyballguy on
nope. you won't blow them unless you overpower them.. that Adcom should be a nice match for your RTi6's.PolkFest 2012, who's going>?
You're ok.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
The only way you could blow them up is if you had the volume up too high. In which case you would blow your ears, so it wouldn't matter about the speakers!:eek::DMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
