Speaker cable termination help
skipf
skipf Posts: 694
I just got a new set of speaker cables with nanners on the speaker ends and spades on the amp end. Dummy me didn't check my M-500t amp thoroughly before ordering the cables, and the terminal posts on the amp are the old style plastic terminals designed to accept bare stripped wire. Does anyone know of an adapter that I can screw down on the spade connectors that has a pin or flexible pin end that will fit in the old style amp terminals? I'd hate to have to cut the spades off of my new cables.
Post edited by skipf on
  • zingo
    zingo Posts: 11,258
    edited January 2008
    Monster makes some convertable systems where you can screw different types of tips onto the same cable. Where did you get the cables? Is there any way for exchanging for what you need?
  • Face
    Face Posts: 14,340
    edited January 2008
    If you have barrier strips, they are adapters available on ebay on audiogon. They allow you to use bananas or small spades.
  • skipf
    skipf Posts: 694
    edited January 2008
    Nah, not monster cables, they are Cardas. Guess I'll have to make something or go ahead and cut the spades off the cables. I've seen nanner connectors that will attach to spades, but not pin or soft pin connectors.
  • Face
    Face Posts: 14,340
    edited January 2008
    http://cgi.ebay.com/ADAPTERS-MCINTOSH-FISHER-EICO-Old-AMP-BANANA-PLUG-SPADE_W0QQitemZ150199777956QQihZ005QQcategoryZ32838QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    That is what I'm talking about. Look at the bottom picture, there's a hole in the back that a pin could be inserted in and locked down.
  • skipf
    skipf Posts: 694
    edited January 2008
    Face, I saw those too, but don't think they will work with the M-500t. The terminal posts on the amp have a raised plastic ring at the base of the terminal with a slot on each side for the wire to lay in. The screw down portion of the terminal is smaller in diameter than the base cup and is designed to clamp the wire tight against the bottom of the base cup. Spades don't work because it only contacts plastic if you tighten the terminal down. The bottom cup won't let the spade connector contact the plate at the bottom of the terminal. Thanks for looking though and the reply.
  • Face
    Face Posts: 14,340
    edited January 2008
    Gotcha now. Best of luck.
  • ShinAce
    ShinAce Posts: 1,194
    edited January 2008
    If a single end of the spade lug will fit, bend the other backwards and then crimp the entire lug in half.
