How high to put FXI3?
I just bought some FXI3s (black) [although I am considering the white] but I dont know how high to put to speakers? any recommendations? ear level height? or higher?
Another question:
I have RTI8 as front.
I will have CSI5 as center channel.
I have FXI3 as sourround.
What should I use as rear? (perferably speakers on clerance @ frys:))
Another question:
Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
"The more time you spend researching here, the less money you will have"
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
Post edited by Gizmo99 on
The standard recommendation is 6 feet.
Welcome to Club Polk.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Thanks!
I've searched the forums and some say I should place this in the "null area", while other say place the speakers a little bit back behind the listening areas.
Which one gives the best effect of sourround?Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
2' - 3' above ear level when seated seems the standard recommendation. I have mine higher than that but pointed at a spot 2' behind and 2' above my head when seated.
I was able to get brand new FXI3 (black) for 149.99 and I am looking to get another set for the rear. However the FXI3 (white) is selling for 200 dollars at Frys. Do you guys think its a good deal?Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
Wow where did you get FXi3's for $149.99. I'm assuming that's the price for a pair, right?
Local frys, it was the last pair but they had another pair (white) for 200.Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
that is a good deal for a pair of FXi3's. I think I might've snatched the last pair at frys.com though
