newbie amp question... sorry
jsbradbury
jsbradbury Posts: 1
edited January 2008 in Electronics
k, so I've been trying to refrain from posting this, as I'm sure you all are tired of amp questions. However, I can't seem to find a thread that has the info I'm looking for... I'm currently running a Denon AVR 4806, Polk Rti12's, CSi5, FXi5's for the mid, and FXi3's for the rear surround. What I was wanting to do was run 3 mono amp's. Something like the Outlaw 2200 M-Block for the center channel seems very appealing to me. I would like to try and match it with something for the RTi12's. I don't want to buy a multi channel amp because I think the Denon puts out plenty for the FXi series and I don't plan on upgrading anything else anytime soon. Can you guys give me some recommendations on a mono amp that puts out enough power to properly run the RTi12's? They're rated to 500W, however, I know enough from my reading here that I will sacrifice quality for quantity of amperage. I use my system primarily for movies, I have a Samsung BD1400 Blu Ray player, and the Toshiba HD-30 hd-dvd player into my Mitsubishi WD-73727. I do some gaming with an XBox 360 and minimal music.... suggestions, ideas? Am I stupid for wanting the mono amps? Thank you in advance!
  • danger boy
    danger boy Posts: 15,722
    edited January 2008
    the Outlaw mono block amps will do great on your center and RT12's without any problems.. that's plenty of power for them..
    PolkFest 2012, who's going>?
  • Sherardp
    Sherardp Posts: 8,038
    edited January 2008
    You started off just as I did, the Outlaws will do a wonderful job with the 12s and your center. I too started with 3 M2200s on the fronts and let the receiver ran the rest. I just bought a D-Sonic Magnum 1000s which now gives my 12s 525 watts. Icepower sounds awesome, though some arent into class D amps. So the outlaws will do the 12s justice. I also suggest you try finding them used or B-Stock, Ive seen them sale as low as 175 bucks. Check Audiogon.com as well. Welcome to the club.
