budget center channel
edited January 2008 in Speakers
just starting the build of a basic 5.1 surround setup. looking for thoughts on center channel. I hear alot about matching the center to the fronts. currently my fronts are monitor 30s (which will eventually be rear surrounds)will probably stick with monitor series for budget reasons. looking for a matching center but due to restrictions for height cs1 is out. both csm and csi25 will fit (just) any thoughts. also have velodyne vx10 su currently.
Post edited by umbagog1 on
    edited January 2008
    Why do you have restrictions for height? You really want to have matching front and center speakers for any 5.1 setup, so I'm curious why you can't go with a CS1 or CS2.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
Welcome!
Welcome!
