All Channels Driven
math wizard
math wizard Posts: 106
edited January 2008 in Electronics
I've searched this forum and have not found a satisfactory answer to this question. How can I tell if the power rating for my AVR is for "all channels driven?" I have a Yamaha RX-V2500 which is rated at 910 watts (130 watts x 7 channels). This is a considered a high current amp. From the users manual, it is not clear if it means all 7 channels or just 2 channels. Can someone here tell the answer or atleast point me in the right direction so that I can find it? All replies are appreciated.
Processor - Emotiva UMC-200
Pre-Amp (2 Ch) - Emotiva USP-1
DSP Minidsp nanoAVR DL
DAC (2 Ch) - Emotiva XDA-2
Amp (Fronts) - Emotiva XPA-2
Amp (Center/Surrounds) - Emotiva XPA-3
CD - Emotiva ERC-1
Fronts - Polk Audio RTi 12
Center - Polk Audio CSi5
Rears - Polk Audio RTiA1
Sub - Epik Knight
Sub EQ - Velodyne SMS-1
Monitor - Sony XBR65X850C
Blu-Ray - OPPO BDP-203
Network Media Player - Chromecast Ultra
Power Conditioner - APC H15
Power Conditioner - Emotiva CMX-2
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub
Post edited by math wizard on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2008
    I seriously doubt an receiver of any maker will put out 930 watts total. But saying that must AVR / receivers have inflated true output rating. Look at the tread "Show me your guts" and look for some amp's which are true rated output, start looking at the transformers, the filter caps needed to put that kind of wattage.
    Saying that relax if your receiver have preamp outputs, enjoy it today, learn and or grow from it.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • wallstreet
    wallstreet Posts: 1,405
    edited January 2008
    Probably something in between. You certainly won't get 130x7 with all channels driven. I found a review for the 2600 which is a 130x7 also. At 6 channels driven at 1KHZ, the output was 119wpc. With 7ch driven, your results will even be less. Here's the link, http://www.soundandvisionmag.com/receivers/1497/test-bench-for-shootout-three-mid-price-av-receivers-page3.html
    IMO, those are respectable numbers.
  • math wizard
    edited January 2008
    Thanks. I look at the review and thought that the numbers are respectable also. Not far off from the spec. at 6- channels driven. I could not find the
    "Show me your guts" thread.
    CD - Emotiva ERC-1
    Sub - Epik Knight
    PVR - DirecTV C61k
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited January 2008
    Yamaha rates them with two channels driven. Here is a review, it did meet the published specs:
    http://www.audioholics.com/reviews/receivers/yamaha-rx-v2500/rx-v2500-benchmark-tests-part-1
  • wallstreet
    edited January 2008
    You know what's interesting about that review is that in 4 ohm setting, the power output at 20hz for 1ch is 199wpc as opposed to 147wpc in 8 ohm setting. This is what I would expect. But when you look at the 2ch ratings for 4 and 8 ohm, the power is less in 4 ohm (119wpc) than 8 ohm (135wpc). This is not what I would expect.
  • disneyjoe7
    edited January 2008
    Sorry I gave you the wrong thread name but here's a link of what I was talking about. http://www.polkaudio.com/forums/showthread.php?t=26433
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ward91
    ward91 Posts: 338
    edited January 2008
    my old marantz sr4400 apparentley was capabale of driving all channels continuasley, however one day i decided to try this by splitting a stereo signal into 3 sets of them and then compensating for the loss over each chanel by adding 6db. it did drive them without clipping (to my reconing), but the sound was quite harsh. and the amp soon got verry hot.
    one thing i cant understand is why the amp said power consumption was 315watts and the power output was 6x 80wrms @ 8ohm and 6x 95wrms @ 6ohm (min), that means that the out is bigger than the in , that is impossible.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • unc2701
    unc2701 Posts: 3,587
    edited January 2008
    wallstreet wrote: »
    Know that impedence switch in the back? That's why you leave it in the 8 ohm position.
    Backburner:Krell KAV-300i
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    My HK has this. Which I take as all channels driven.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
    mhardy6647 Posts: 34,930
    edited January 2008
    The FTC had (still has, AFAIK) a very stringent way to report power for two channel amplifiers for home use. Car audio and multichannel formats always were and still are exempt from the letter of the law. As a consequence, there is no standard, and manufacturers can (and do) report whatever they see fit. The better manufacturers at least tell you what their standard is.
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2008
    I'd doubt it. My Onkyo TX-SR702 is rated at 7*100W, yet IIRC in Sound and Vision they tested all channels driven and found it to be only 52WPC.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
