Help needed connecting PSW125
wikksmith
I'm connecting a PSW125 to a Sony AVR (HT-DDW700). It's a 5.1 AVR but the sub output is a speaker-type connector, instead of a coaxial (RCA) plug. I assume it is an amplified rather that a preamplified output. How do I wire the PSW125?
Thanks, wikksmith
Thanks, wikksmith
Post edited by wikksmith on
Ya, I think you are kind of stuck. The subwoofer outputs on the AVR are powered, so that is a no go. You will either have to get a new AVR or sub. You COULD bypass the amp and wire it straight to the driver, but I would not recommend unless you really want to and know what you are getting yourself into.
