Receiver to go along RTi10 and RTi6
black magic
black magic Posts: 669
edited January 2008 in Speakers
Hello all,
I am a stranger to the home theatre side of this forum. I am mostly into car audio, however I've decided to up my game in my pathetic excuse for speakers in my room.
I'm still a student, and I don't spend as much time in my room as I do in my car. I'm looking at getting the RTi10's and RTi6's. I've decided to go without a sub until I find a place for it, so I'm going to be without deep bass extension for a while.
I'm looking for a receiver I can use with these speakers and with a sub for the future. Now, although I know a little about car audio, I am quite a n00b in the home theatre area. The only major difference I noticed is the difference in resistance. Most home theatre speakers are 8ohms, where as mobile/car speakers tend to be 4ohms and in many cases wired down to 2 ohms.
Anyways, this is the receiver I am currently looking at:
http://www.crutchfieldcanada.com/Sony_STR_DG710_Home_Theater_Receiver_p/158stdg710.htm
In car audio, Sony definitely lacks quality, but I hear their home theatre lines are a little better. Please feel free to make recommendations. Like I said, I am very unexperienced in this area.
Thanks!
Post edited by black magic on
  • ben62670
    ben62670 Posts: 15,969
    edited December 2007
    For this one use the search feature. This type of thread has been beaten to death lately. Especially with the RTI's. Sony receivers are like the head units. Go HK, or Denon.
    Happy hunting
    Ben
    Ben
  • jerry22m
    jerry22m Posts: 14
    I have the Rti10 and 6s hooked up to a Pioneer VSX-84TXSI 140wpc works just fine.
  • Sherardp
    Sherardp Posts: 8,038
    ben62670 wrote: »
    Happy hunting
    Ben
    I wouldnt say all of that now, I have a Sony 7100ES, though I am using external amps the thing is a beast of an AVR. Nothing wrong with Sony at all. Just pick a receiver that has all the bells and whistles on it that you want/need in the future and has preouts on the back.
  • black magic
    Thanks for the inputs everyone. I'm reading a lot of reviews and I'm gonna try to audition as many as I can. I'll definitely keep everyone updated.
    thanks again
  • mrloren
    mrloren Posts: 2,474
    edited January 2008
    I am a Sony fan too,
    The lower end Sony receivers are not that great but when you get into the high end stuff like their ES. The 710 you are looking at in NOT in the high end. I would look 2 modles up from there like the 910 or the DG1100.
    I have friends that hate Sony audio products till they come over to my house. now most of them own Sony ES receivers. Ebay was good for their receivers that started with the letters D, O, H, & Y.
    I am currently running a 5300ES in my family room with RTi8's and this is soooooo sweeet.
    My bedroom has a 2100ES with Rti4's It is great
    Sony high end with Polks are great.
  • black magic
    edited January 2008
    Thanks for the info. I didn't realize that the RTi10's require a decent amount of power. here are my final choices after doing a little bit more research.
    Sony STR-DA5000ES
    Harman Kardon AVR 635
    Pioneer VSX-81TXV
    Yamaha RX-V2500
    Sony STR-DA3000ES
    Any final opinions?
  • Sherardp
    edited January 2008
    Just make sure you have all the bell and whistles on it. Do it right the first time. Take pre-outputs, Hi Def Decoding into consideration as well.
  • nm4710
    nm4710 Posts: 97
    edited January 2008
    I'll add to this as well...Sony is unnecessarily maligned by the audio community. Like other manufacturers (Denon, Onkyo, Pioneer) their low end products leave much to be desireable. But their ES and mid-range (DG910, 1100, etc.) hold their own against anything in their price ranges.
    I just picked up an open box sony for my bedroom 5.1 setup...after plugging it into my main room w/an all RTI setup I was shocked...it sounded far superior to the HK I just bought a few months ago. The HK is now driving the bedroom setup and the Sony is the star of the show. It is not an ES model (sony's top line) although interestingly the power supply says ES on it.
    It's especially funny b/c I originally bought the Onkyo 605 which is universally lauded here and at avsforums...when I got it home and plugged it in i was really disappointed. Tons of features but the sound was very thin and even harsh. I thought the HK was a huge upgrade but I'm honestly wow'd by the sony.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited January 2008
    Yeah, the Onkyo 605 is disappointing. It has a very sterile sound in my opinion and only has Audyssey 2EQ, so it does zero equalization of the subwoofer (which is where most equalization is needed). The 705, however, has Audyssey MultEQ XT and sounds amazing. Probably outside of the OP's price range based on that original link he posted, but it does give you all the bells and whistles and lets you matrix 5.1 lossless to 7.1 (which the 605 does not). I'm running the 705 with older Polks - RTi70 mains, CSi40 center and 4 RTi28 surrounds (with SVS 20-39CS+ sub) - and it's the best sound I've had in my room thus far.
    Of the other brands listed, Sony and Pioneer tend to be on the brighter side, which I don't particularly like with the Polks. Yamaha and HK are warmer sounding, which works better with the general characteristics that Polk speakers have historically exhibited. That said, I don't particularly care for the Yamahas and I don't think their YPAO auto setup works very well. I would say the HK, out of that list and ignoring Onkyo as an option, would be the best match to Polk speakers. But if I'm being honest, I think Denon receivers tend to have a sound to them that works really well with Polks, so he should definitely look for a comparable Denon in his price range. If I hadn't found my Onkyo 705 for under $500, I probably would have ended up with a Denon myself.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Meechsterlee
    Meechsterlee Posts: 73
    edited January 2008
    Sony STR-DA5000ES
    Pioneer VSX-81TXV
    Yamaha RX-V2500
    Sony STR-DA3000ES
    Any final opinions?
    I am finding my 10's could use a bit more than my Sony has to offer...B&K time?
    SAMSUNG HL-S42 DLP
    harman/kardon AVR225
    SONY PS3
    polkaudio RTi8's
    " CSi3
    " RTi6's
    Velodyne VRP1000
  • black magic
    edited January 2008
    All of the stores in my area are sold out of the 10's as of yesterday :( I think I might have to settle with the 8's.
    Right now the battle is between Sony and HK, because they sounded good to me. I will try an audition some Denon and Pioneer ones as well. The thing i like about the Sony ES, is that they put out a decent amount of power (I'm looking at 3000ES or above)
  • tcwong
    tcwong Posts: 33
    edited January 2008
    I have the RTI8, and the sound is open and very clear. It just weak on the bass comparing to the RTI10. When I audit the new RTIA7 vs A5, i like the A7, but I settle for the RTI8 for the price. 1 pair of RTI8 cost less than 1 RTIA7.
  • nm4710
    nm4710 Posts: 97
    edited January 2008
    If that's you're receiver and that's what you think...essentially no receiver is going to cut it. Do yourself a favor and get a nice outboard amp. I hope that's what you meant by saying you were gonna go B&K. They make great stuff!
  • sdcfan19
    sdcfan19 Posts: 56
    edited January 2008
    Sony STR-DA5000ES
    Pioneer VSX-81TXV
    Yamaha RX-V2500
    Sony STR-DA3000ES
    Any final opinions?
    I'm running my 10's with the Pioneer VSX-1017. Sounds great for me and I would expect even more out of your system with and of these amps. I would go with either the Pioneer or the HK.
    Samsung Plasma (50A530)
    Bell ExpressVu 6100
    Toshiba PRV (RD-SX35SU)
    Pioneer DVD w/upconvert (DV-490V)
    PlayStation 3
    Harman Kardon AVR 354
    Polk CSi A6 Center
    Polk RTi10 Fronts
    Polk M20 Rears
    D-Box Sub
    Harmony 880
    Acoustic Research/Rocketfish cabling
  • chargerman426
    chargerman426 Posts: 419
    edited January 2008
    i would definitely go with the HK. i have an AVR 745 i use to use it to power all my speakers (i had 5.1 then 7.1 now 5.2) but now am running a separate amp on the fronts now. but when i did run just the HK it worked and sounded great. also dont be fooled by HK's low power rating on there web site the HK's are usually 30 to 40 watts under rated. i dont know the pioneer AVRs but i would think they would be fairly accurate especially if you get the elite seres. hope this helps
    If life had more tubes it would be a lot smoother.
  • black magic
    edited January 2008
    Thanks... I'm impressed with the HK quality, what worries me is whether or not they can handle the rti10's as they require a decent amount of power...
  • chargerman426
    edited January 2008
    i ran my rti12 with my HK for a little while it was only for like a day or two and it was about a month ago but if i remember correctly they sounded fine and with the HKs you will get all the pre-out so if you wanted to add a separate power amp you could
  • black magic
    edited January 2008
    Thanks a lot for the feedback everyone! I'll keep you guys updated.
  • MADGSF
    MADGSF Posts: 603
    edited January 2008
    I ran my 10's with an Elite AVR alone for a couple of years and it sounded good but you could tell they wanted more power. I think the 8's would of been fine with my AVR though.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • stangjason
    stangjason Posts: 341
    edited January 2008
    I love my refurbed H/K 635 I picked up a few months back it makes my RTi8's, CSi5, and fxi3's sound oh so nice!
    Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
  • Willow
    Willow Posts: 11,219
    edited January 2008
    Sony STR-DA5000ES
    Pioneer VSX-81TXV
    Yamaha RX-V2500
    Sony STR-DA3000ES
    Any final opinions?
    You can go the HK route (I did and love the set up) but I would suggest a lesser model to save cash and buy a seperate amp(s). I have a 335 paired w/ marantz monoblocks (200wpc each and an outlaw m200 for my centre again 200w) this will kill the wpc that the HK puts out.
