Need help in finding a receiver and projector for my Polk speakers
raavango
raavango Posts: 3
edited December 2007 in Speakers
I am a newbie and need some help with a receiver and a projector. I have
a sharp 52 inch 1080p lcd tv (sharp 52d92u)
set of polk monitor 70s, set of polk monitor 40s and set of polk monitor 30s,
a polk psw 10 sub and also a velodyne vrp 1200 sub
Can you guys please suggest a projector/screen and receiver which I can use for the long run.
The basement is 23 x 15 and the living room is 16 x 16.
I would put the tv in the living room and the projector in the basement. I want to use the multi-zoning capabilities of the receiver so that I can run both the setups in the living room and the basement from one place (maybe the basement). I can buy another set of speakers for the living room. OR I can run a stereo setup in the living room and a 5.1 setup in the basement. If it is too complicated to use the multi zoning I can buy a HTIB for either the living room or the basement.
Post edited by raavango on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Think separate systems.......multi zoning rigs are really only good for when both will never be used at the same time, which counts out most 2 TV homes.
    As for projectors, look into all technologies to see what fits your needs. LCD, DLP both have their places. Brands like Panasonic, Sony, BenQ, Optoma, Infocus all have nice units.
