EX-10 Speaker info
bdcc11
bdcc11 Posts: 4
edited September 2001 in Car Audio & Electronics
Fry's has EX-10 speakers on sale for $40.00 and I can't find specs for them anywhere. I can find DB-10 and other subwoofers on the Polk website but not the EX-10. Is is a good speaker? I want to check box design before purchasing and I need the specs.
Post edited by bdcc11 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Great sub, bought one myself just 2 weeks ago. I have the specs at home, I'll post in a couple hrs.....
    Cheers,
    Russ
  • RuSsMaN
    1mm thick mineral filled polymer cone, injection molded polypropylene dustcap, rubber surround.
    4 layer, 2" voice coil, vented pole piece.
    4 ohm, 20-400Hz, 150 wrms-300 peak, 92dB spl
    Enlcosure sizes:
    Sealed- .65ft
    Ported- 1.0ft port-3"x9 7/8"
    Bandpass- total 1.1ft, front chamber .5/rear .6 port-3"x9 7/8"
    Fs 32.47 Hz
    Re 3.34 ohms
    Qms 8.27
    Qes .48
    Vas .45
    Depth - top mount 4 11/16", bottom mount 5 1/16"
    Diameter - 9 1/16"
    Cheers,
    Russ
