Psw10
Nick5
Nick5 Posts: 4
Santa Claus delivered a PSW10 to compliment my Monitor 50's.
I have an old Luxman R115 70 watts per channel I think as I can not locate my manual. Does the Luxman have a Sub Out on the back?
The entertainment system is to heavy to move myself.
How do the new Onkyo Home theater (TXSR 505, 605) systems compare to the old stuff I have?
Post edited by Nick5 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited December 2007
    The R115 doesn't have a sub-out, but it does have a set of preouts, which you can run to your subwoofer if you don't want to use a high (speaker) level connection.
    Cheers,
    Russ
  • McLoki
    McLoki Posts: 5,231
    Nick5 wrote: »
    If you plan on just running 2 speakers (or two with your subwoofer now) - keep what you have, it will blow away most common AVR's now (lets say most AVR's under $1,000). If you want to try surround sound - you really will have to upgrade as yours does not support that feature.
    You certainly get more bells and whistles with even the cheapest AVR now compared to what you have, but for 2 channel listening, I do not think sound quality will improve over what you have without spending some significant cash.
    Michael
