Emotiva and Subwoofer hookup -help!
mhartman29
My parents had an unused Polk PSW250 sitting around their house, which they graciously offered to give to me. While that is shipping to me, I'm trying to figure out what kind of cable I need to get to hook this thing up.
I have the Emotiva lmc1/lpa1 combination. Since the 250 is a powered subwoofer, should I use a subwoofer cable from the LMC Subwoofer output of the LMC into the subwoofer? Or do I need to connect the subwoofer to the LPA (power amplifier) and then connect it with speaker wire?
What's the proper way to do this?
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Post edited by mhartman29 on
LMC1 Sub out to the subTV...............Hitachi 42hdS52a plasma (sexy one with the swival)
Pre/Processor - Emotiva MMC
Seven Ch AMP - Emotiva LPA
Fronts - Tyler Acoustics 7U's
Center - Polk LSIC
Sub - DSWPRO600
DAC - Music Hall 25.3CD - Marantz cc4001
Blue Ray - PS3
Speaker cables - Audioquest cv4 dbs
Interconnects - MIT AVT1's
Power Filter....Monster HTS 3500 MKII -
I hooked mine up yesterday and didn't set the front speakers to small on the lmc menu. I guess it is factory set to large and couldn't figure out why the sub wasn't working. :duh:
That was the second thing I was wondering. It seems like you need to set your front speakers to "small" in order to use the subwoofer with the lmc. But, I have RT3000s for my front speakers. They aren't small at all. Does that designation really matter?Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Ultra speaker cables -
I couldn't tell a difference between the large and small setting. I have untrained ears though.
It isn't the size of the speakers that matters. It is recommended to set your speakers to small with a crossover of 80 so that all the real deep bass is handled by the sub. It puts less strain on the speakers & the sub has the ability to go a lot lower than the speakers are able to.
I hate to think of what watching the War Of The Worlds would do to a pair of drivers in speakers!:eek:Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
My speaks handle that movie and then some,but then again,they do have 6 12 in. woofers between them.If you have big floorstanders,like the 3000p's,with a built in sub,setting it to small will kill your soundstage.Read your specs,play around a bit with the crossover settings.A sub should pick up right before your speaks start rolling off.
If your AVP won't let you set it to large,do so in the player setup and use analog cables to your AVP or receiver.HT SYSTEM-
lsi 9's -
thanks for explaining that.
OK, I'm sorry but I'm really confused. Polk seems to say you shouldn't connect your subwoofer through the SW output, since the receiver might have a low pass filter. Not sure if the emotiva lmc has a low pass filter on the SW output or not -- I'm trying to look that up right now. If it does, it sounds like that is not the option to use.
It sounds like the Polk SW should have a have "LFE" line input that bypasses the subwoofer's built-in low-pass filter. But, if setting the speakers to small is the only way to get the SW output to work that probably isn't ideal for my situation either since, as tonyb mentioned, that would kill the bass output from my RT3000s.
What's the solution???? Argh!Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
I'm not sure about the LMC, but i would figure it to be similiar to the MMC.
If you set the speakers to large, set the Sub to enh (enhanced) and your sub will play in all modes. (This is if the lfe has this option in the speaker setupTV...............Hitachi 42hdS52a plasma (sexy one with the swival)
Center - Polk LSIC
Sub - DSWPRO600
Blue Ray - PS3
