Fxi A4 Placement.
bykes
I will be hooking up a set of Fxi A4s for rear surrounds. I live in a small apartment and my couch is right up against the wall I will be hanging them from. My question is should I put them at ear level or a few feet above?
Thanks.
Thanks.
Post edited by bykes on
A few feet above, and if possible, to the side of, the seated listening position.
Experiment with the bi/di pole settings, too.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
thanks
In one of my apartments, I put the surrounds on the sides of me and that worked great too. It just depends on the room and what you can get to sound best.
