RTi A9 versus RTi12
solidus28
solidus28 Posts: 83
edited December 2007 in Speakers
I'm pretty sure I already know the answer to this is yes, but wanted to check with you guys anyway. I currently have 4 RTi10s and a CSi5 for HT and at some point would like to replace my mains with RTi12s and use the pair of 10s to make a 7.1 setup. There is no way I have room to do that where I currently live and since the old RTi line is on its way out, I figured it will be a little more difficult to find a pair of RTi12s when the time comes. I will definitely keep an eye on the used market when I start looking, but my question is, will the RTi A9s be just as good/better? They should match up ok with the CSi5 and RTi10s, right? Thanks, guys!
Post edited by solidus28 on
