Alpine Imprint KTX-100EQ Vs PXA-H100
Kinetic
Guys i have a CDA-9887 and for using the imprint module, i have to buy the Alpine KTX-100EQ, but now Alpine have two new models, the CDA-9884 and the CDA-9886.
the CDA-9884 and the CDA-9886 requires the PXA-H100 instead of the KTX-100EQ that the 9887 uses, why is that?
i was planing on buy the CDA-9886 for my other car, but now i would have to buy also the PXA, instead of using the same KTX-100EQ in both HUs (i have to spend double).
whats the difference between those 2 models, and why Alpine does the "same thing" but with different names, now i have to buy 2 of them instead of just one of them.
does anyone knows anything about this???
PXA-H100
KTX-100EQ
PXA-H100
KTX-100EQ
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Polk Audio SR 6500
G35
Post edited by Kinetic on
why not just got another 9887 for your civic?2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
The CDA-9886 does not have any type of built in processing like the CDA-9887. The PXA-H100 will give the 9886 the same processing that the 9887 has, plus the ability to use the imprint automatic setup.
As to why they have different modules....I do not know.
With the 9887 you just plug the imprint module into the front of the receiver. With this it seems that you can't do that as it has the a connection port on the actual imprint unit.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
eloplayspolo wrote: »why not just got another 9887 for your civic?
i dont want the same, and the 9887 is more expensive, but i also want to wait until the 9884 and 9886 reviews come outZ
Polk Audio SR 6500
G35
KnuKonceptz MKS Kable -
1996blackmax wrote: »The CDA-9886 does not have any type of built in processing like the CDA-9887. The PXA-H100 will give the 9886 the same processing that the 9887 has, plus the ability to use the imprint automatic setup.
thanks a lot, i was a little bit confusedZ
Polk Audio SR 6500
G35
the diffrence in price of the 9887 and the 9886 should be about 100 us i would think.... the module that u need to use the imprint with the 9886 is prob more2013 Toyota Prius
Mosconi 6to8 v8 -
Crutchfield had the CDA9884 and CDA9886 in stock you can probably read reviews there. The 9886 takes the place of the 9885 and the 9884 takes the place of the 9883.
The 9887 is still the better unit.
