Bookshelf speaker Questions
I am setting up a stereo system in my bedroom, but want to use small speakers there. I have had great luck with my Polk ceiling speakers, and my Polk powered 12" sub, but not sure if I should go Polk bookshelf. Below is a pic of the stereo, and would like your advice as to what speakers would be small, but have that dynamic sound. I will be playing CDs, but might even put my turntable back in service. I like crisp sound and like to hear symbols clearly. For some reason, it seems that the symbols are muddy from many speakers.
My artwork is at http://www.woodensail.com
Post edited by Iagent on
Partly depends on your budget did you check out the Lsi7s or Lsi9s?
Tweeter lets you take stuff home to demo if you have one near by. I took home Lsi15s and then returned them a week later- no worries no hassles.Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
phipiper10 wrote: »Partly depends on your budget did you check out the Lsi7s or Lsi9s?
Thanks, I think I will need to go there and check them out.
Budget will allow those Lsi models, so I guess I should give them a listem.My artwork is at http://www.woodensail.com
