My first... 2-channel rig
m00npie
m00npie Posts: 697
edited December 2007 in 2 Channel Audio
I have attached a picture of my new\used 2-channel office rig. Everything is used except for the rack and speakers stands. Some of the equipment was purchased from a few forum members.
The setup...
Speakers - LSi7's
Amp - Parasound HCA1000A from HearingImpaired
Amp - Parasound HCA1000A from Dorokusai (This was free since I permitted a leg hump)
Pre - Parasound Model 2100
SACD - Marantz SA-15S1
TT - NAD C555 from SolidSqual
Interconnects – AQ Columbia
Phono Interconnect – Looking for ideas
Speaker cable – AQ Type8 for now
Power cables – Signal cable
The layout in my office is not optimal but it sure beats listing to my primary rig in the other room from a distance. This is my first shot at vinyl so I have lots to learn. Thanks to HearingImpaired for a ton of info to get me started.
Post edited by m00npie on
  • danger boy
    danger boy Posts: 15,722
    that is top notch! Great looking system.
    enjoy!
    PolkFest 2012, who's going>?
  • dkg999
    dkg999 Posts: 5,647
    Nice! How ya gonna get any work done with that system crankin is beyond me :D
    DKG999
  • ben62670
    ben62670 Posts: 15,969
    Nice. Your off to a great start:p Watch out for the upgardeitis bug that has been known to go on around here. Also I was wondering how you like your AQ speaker cables(maybe you have a comparo?). I have tried a couple of their cables. The type4, and the CVS4's (dbs), and I really like the CVS4's a lot.
    Ben
    Ben
  • Face
    Face Posts: 14,340
    Looks good!
    HearingImpaired helped get back into vinyl also, great guy!
  • hearingimpared
    hearingimpared Posts: 21,136
    Nice rig Kelly, I hope you really enjoy it. BTW we need to get you a clamp for your TT.
  • m00npie
    m00npie Posts: 697
    ben62670 wrote: »
    Ben
    I know the upgardeitis bug all too well with my HT rig. As for the Type 8's, I had those in my HT system. I'm trying a pair of Zingo's cables so these were free to use for now. The Type 8's were nice with my RTi's since they seemed to help tame the highs a bit. I feel they are a little too laid back for the LSi's so I'm in the market for either AQ Gibraltar or MIT Shotgun s3's
  • Shizelbs
    Shizelbs Posts: 7,433
  • jflail2
    jflail2 Posts: 2,868
    Beautiful setup man. I'm starting to itch for a 2ch rig for my office, and haven't even finished my ht setup yet...
    Where'd you get the rack? That'd be the perfect size for my room.
  • dorokusai
    dorokusai Posts: 25,576
    That looks fantastic. Just get an AQ phono cable to match the rest.
  • m00npie
    m00npie Posts: 697
    jflail2 wrote: »
    I got the idea from Ricardo in the system showcase and bought it from uniquestylesolutions.com The rack that I have is the BL304 series.
  • SolidSqual
    SolidSqual Posts: 5,218
    Man that turntable looks way better in your system than it did in mine. Congrats!
  • dorokusai
    Upon closer inspection....I might suggest a set of hockeypucks between the amps for better air circulation. Since you're bi-amping, use the bottom one for your highs.
  • beardog03
    beardog03 Posts: 5,550
    Very nice 2 ch Rig ya got there !
    I really like the 7`s myself..
    How do you like those stands?>
    I was looking at getting some for my 2ch rig also..
    Congrats on the new system...!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • m00npie
    m00npie Posts: 697
    dorokusai wrote: »
    Great suggestion for air circulation. It is really kind of tight between them so giving them some more breathing room can’t hurt. As for hookup, I'm actually running each amp in mono. Even though Parasound strongly tells me otherwise, I have not had any issues yet.
  • SolidSqual
    You might also fill the legs of the VTI stands with sand. I have several VTI racks and have done the same.
  • hearingimpared
    Well not to break balls here but I've tried sand and it is very messy and it holds moisture and gets moldy. I used #9 lead shot that I purchased from a local gun dealer in my VTI rack . It's easy to pour in and it makes that rack D E A D!!! and on the heavy side so there are no resonances, or vibs or any nasty getting through them. Make sure you pull the rubber plugs in the pillars that block the rails. When you pour the shot in, make sure you do it from the bottom where the points are so you can move the rack in different directions which make the rails fill with shot easier.
    Also the hocky pucks are a great idea but I think you need to get at least three inches between those amp. I used Isoblocks from Mapleshade when I had the Parasound. They are only $24 bucks for four of them and you simply place them under the existing feet. These are great little tweeks when you have no choice but to stack. This should give the bottom amp and top amp some good breathing room.
  • wingnut4772
    wingnut4772 Posts: 7,519
    That's pretty sweet. I sure do miss mine. Enjoy it!:D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • dorokusai
    I second that, sand is BS. Lead shot.
    If you feel like killing yourself later, you can always eat a few handfuls with your oatmeal in the morning. Sand just gets you discharged with alot of laughing.
    I'd cut my own wood before I'd buy a tweak from Mapleshade but is only $24. The wood blocks are a great idea but the owner is one step away from blasting off to Pluto with the Machina Dynamica crew. The Mapleshade recordings are stellar but that's about it.
  • SolidSqual
    Awww to hell with you old grumps! Guess you are both just too cool for school. I couldn't get lead shot into the VTI holes because they were too small . . . but if she can jam it in there then your suggestions are spot on.
  • Face
    Face Posts: 14,340
    SolidSqual wrote: »
    Who's she?
  • BaggedLancer
    BaggedLancer Posts: 6,371
    nice rig, good luck with it.
  • TroyD
    TroyD Posts: 13,124
    Looks GOOD man....Fantastic, really. I'd like to get an ear on that rig. Of the LSi's, my pick for pure 2ch is the 7's. I wish I still had mine.
    BDT
    F1nut Posts: 51,997
    LOL.......agreed.
  • m00npie
    m00npie Posts: 697
    beardog03 wrote: »
    I really like the Sanus stands but I do have a complaint about the base of the stand. See the attached picture. The risers are dark grey that look almost black and then they have this grey base that looks as if it is dusty all the time. I guess I could paint it but other than the look, I'm very happy with them.
  • m00npie
    m00npie Posts: 697
    SolidSqual wrote: »
    Mike..... I'm offended! :eek:
    My first name goes both ways but rest assure I go only one way :D
  • beardog03
    TroyD wrote: »
    BDT
    I agree Troy...
    I almost like the 7`s better than the 9`s..
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • hearingimpared
    SolidSqual wrote: »
    he he he, you have to knock the caps off. Some of them, with a little effort, will twist off!!!:p
  • SolidSqual
    m00npie wrote: »
    I apologize :( I'll make a mental note and put you on the same list as my best buds Shirley Curtis and Shaaron McFee!
  • SolidSqual
    m00npie wrote: »
    Ok wait, just read this quote again and I've now confused myself to death.
    You are a man? Yes/No - I am thinking Yes as before.
    You are however; not a cross-dresser, tranny or proponent of strap-ons.
    Do I have it right now? I can't keep up with your sick minds.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Very good lookin' rig,as mentioned...I don't know how you can get anything done,there's got to a little more than just back ground tunes rollin' outa that set-up.
