LSi15 + DSW PRO 600 - setup?
Need some advice to best "tune in" the speaker/sub combo. TIA
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Buttkicker
Post edited by SlowcarIX on
Slowcar (Mustang?) :rolleyes:,
Are you using this setup simply for 2-channel? If so, I would recommend not using a sub with the 15's. They dig pretty deep. In comparison with some more expensive speakers (VonSweikert VR2's) the bass could be a bit tighter, but that is being pretty picky. I have the 15's in my living room and simply crave the tight, deep bass they produce. I don't have a setup recommendation for you if you decide to keep the sub in the mix, but thought I would throw my 2 cents in regarding leaving the sub out.
Having said that... Are you maybe setting this up in a HT application? That's a different story.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
lol...mitsubishi evo IX
its going to be 2 channel/HT rolled in one.my 7.(1x4) HT setup
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
Welcome to forum, and good choice on the Polks:D
Can't help here, but recommend listing all components involved, to get 'big picture' out to the Polk guru's, so you can get this thing set up ONCE!:eek:
Good luckI refuse to argue with idiots, because people can't tell the DIFFERENCE! -
(just so you know...that's not a slow car)
+1 on listing the whole system. it will be easier to give recommendations.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
