How low does music go?
Serendipity
Serendipity Posts: 6,975
edited December 2007 in Music & Movies
Was just wondering -
How low does modern music go? I was always under the impression that it was higher than 30-40 Hz.
But the other day I was listening to "The Longships" by Enya (Watermark), and if I'm correct, it felt like there was subsonic bass. Can anybody with the CD verify this? All I know is that it seemed much lower than I have ever heard.
And that is with the sub set flat, BTW.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • lightman1
    lightman1 Posts: 10,796
    Yep. I hear it's around 12-13Hz. Feltit rather than heard it. WoooWeee!!!
  • Serendipity
    lightman1 wrote: »
    Is that for the entire track or just part of the song? The entire CD seems to have ridiculously low bass.
  • lightman1
    Just part of the song on that track. Mostly towards the end at the crescendo. +1 on the rest of the album, Lots of woofer racking bass. Be careful!
    Gonna go listen to it right now! Thanks for reminding me.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Well, as some reference the last key on the piano A1 is at 28.5 hz if I remember right, there are some pipe organs that can go lower, after that some synth stuff but not anything I really would recommend.
    RT1
  • George Grand
    George Grand Posts: 12,258
    I went to a bash one time and there was a really sharp, cutaway model of an AR-3a, with its 12" woof silently pumping away to a 5 Hz signal. Great demo.
    mhardy6647 Posts: 35,014
    The longest pipe on a large pipe organ (32 foot) has a fundamental of 16 Hz. Practically speaking, that's as low as music goes.
    http://lamc.org/concerts/0708/070000-organfacts.cfm
    Synthesizers are another story.
  • Serendipity
    lightman1 wrote: »
    I was worried when my sub driver was moving back and forth violently but I didn't hear any sound.
    But my sub is set very low so it's not hot by any means.
