removing metal jumpers
klove2
klove2 Posts: 38
edited December 2007 in Electronics
What is the easiest way to remove the metal jumpers on the speaker post. Do you need any tools, to take them off. Can i damage the speaker post if i do something wrong. I am considering bi wiring my speakers since i do not use the surrounds backs i my set up. Is there any one out there that has bi-wired the m60s and notice a diffrence in the sound. Thanks in advance for directions and advice
Fronts m60s
Center Cs1
Rears R30s
Avr Marantz SR-7001
Sub SVS pb-10
  • tcrossma
    tcrossma Posts: 1,301
    Just unscrew the binding posts all the way until they come off and then slide off the metal jumpers. It's very easy, no tools necessary. I did not notice any difference when I bi-wired my Monitor 60's.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • McLoki
    McLoki Posts: 5,231
    Not sure on the monitor series. For my LSi's the jumpers had a hole in the top and a slot in the bottom. To remove them, you only had to loosen the nuts on the bottom post and slot would slide free. For the top though, you had to take the black and red nuts all the way off. No tools needed, just keep unscrewing....
    Good luck.
    Michael
  • john22614
    john22614 Posts: 214
    I biwired my LSi's as described above and didn't notice any difference either....but, it doesn't hurt to do it.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
