What do u think of trying this...?
eloplayspolo
K i have the 2 sets of components ( front and rear ) and i dont have the rear tweaters installed yet, so ive just had the rear off competly, but the other day i noticed i really wasnt that happy with my mids, so i was thinking, my TE1004 has a low pass for the rear chan, how would it sound if i just ran the mids off the amp and used the crossover to set it to say...80hz-200hz? what would u recomend and how do u think that would work out for me?
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Mosconi 6to8 v8
Post edited by eloplayspolo on
Why not turn the rears off completely and live with just the fronts only for a few days and see what you think. You might like it better.
Having the rear mids running 200 down wouldnt really accomplish anything. The main reason for dedicated midbass speakers is to get more of the bass up front as opposed to the rear but if you have the rear speakers running as midbasses it wouldnt really do much except pull the bass to the rear more.polkaudio sound quality competitor since 2005
So you are not happy with the mids period? Having the rear speakers on will not alleviate whatever you feel is lacking from your mids. Upgrading to something else will.
I use rear fill and I mainly do this for my rear passengers. One thing I have noticed is that it also seems to help pull the image a little towards the center, and away from the A-pillar. To me it sounds better than when I am only using front speakers only (can't time align for just one person, when there are others in the car), as the sound gets pulled more towards the A-pillar. Now this is not perfect, and you have to play with the TA and volume settings (rear has to be lower than the front, otherwise the image will get pulled back), but I feel it's a good compromise. .
I am currently just using my front speakers only. They are getting 210 watts RMS from my 4ch amp. I bridged it down to two channels. I just picked up a set of Rainbow Profi Phase-Plug components. They are a little bit up the line from my Germaniums. I had planned on going active with these. If I do that, I will not be running rear speakers as I do not want to add another amplifier. My amp can run the active setup if I wanted to, and I can use the built in amp on the HU for the rears, but I am not going to go that route. If I go active I plan on being able to use the TA function on my HU for the tweeters and mids separately. Still trying to decide on this.....Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
heh u missunderstood me again, i would only add mids in the rear therefore having 2 mids in front, 2 mids in rear, 2 subs, and 2 tweaters.2013 Toyota Prius
Mosconi 6to8 v8 -
No, you did not explain yourself correctly. Read you post again, and tell me where it was mentioned that you were going to go with four mids.
Either way, why in the world would you want that many mids? As I stated before, if you are not happy with their performance it may be time to start looking elsewhere, or to look for a dedicated midbass driver.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
i said the rear tweaters wernt installed.... i also mention a low pass filter and said "what if i just ran the mids"2013 Toyota Prius
Mosconi 6to8 v8 -
mmm
maybe this and stupid advice, and is not really and advice, i just figured out.
what about putting the second mids in the front with a kick panel?
so one set of mids and tweeters in the door, and the second in a kick panel but without the tweeters..
please correct me if i am wrongZ
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
KnuKonceptz MKS Kable -
it would work and be cool, however my car is too new, i would have to go to a shop and pay hundreds of bucks.2013 Toyota Prius
Mosconi 6to8 v8 -
maybe you can try putting the extra mids in small sealed enclosures which you can build yourself out of 1/2inch mdf and mount them under the front seats instead of mounting them on custom kick panels?
u know as well as i do there is not enough room for that in our car2013 Toyota Prius
Mosconi 6to8 v8 -
Uhm, I measured about 4 inches of clearance under the driver's seat, its not deep enough for an 8 inch sub, but a 3.5x10x12 inch box made of 1/2inch mdf will probably fit snugly under the seat and have just enough clearance for your mid-range driver (you may have to remove the speaker's rear cap though). Anyway, it was just an idea I was also considering for myself hehe. I like your idea of having two sets of mids up front, it would be great if you could just buy the custom kick panels for our car like those available for other makes.
If you do not want to use a dedicated midbass driver, why not use the next best thing. Rainbow makes some kickabass drivers that excel in the midbass department.
Profi line
http://car.rainbow-audio.de/products/introduction.php?lan=2&pro=1&lin=4
Profi components
http://car.rainbow-audio.de/products/details.php?lan=2&pro=1&lin=4&art=231489
Links to downloads regarding these drivers.
http://car.rainbow-audio.de/support/downloads.php?lan=2&kat=3Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin
