why can't CD's sound more natural?
danger boy
danger boy Posts: 15,722
edited December 2007 in Music & Movies
after listening to some vinyl for about 6 month's now.. then listen to a CD, the CD sounds so harsh. is it impossible for them to make CD's that sound more analog or tube like?
the dynamics of a CD is impressive.. but at the cost of sounding harsh on a good system. or even my crappy system.. they still sound harsh. I know I could go out and buy a tube pre or a tube CDP, but that's not the point..
anyonw know the answer to this?
PolkFest 2012, who's going>?
Post edited by danger boy on
    treitz3 Posts: 20,119
    Your ears are telling you the truth.
  • ben62670
    ben62670 Posts: 15,969
    I blame bad mixing. I have heard some good Cd's, and some bad ones. Its very disappointing when your equipment gets better some of your favorite Cd's sound worse:( But you know that.
    Ben
    Ben
  • danger boy
    ben62670 wrote: »
    Ben
    exactly, i try and tweak the system to sound it's best.. and CD's sound good but very harsh. Maybe it's my CDP too? Sony ES, older jobber though. :confused:
  • Face
    Face Posts: 14,340
    Try some warmer speakers/cables.
  • ben62670
    danger boy wrote: »
    Hey man the best advice I have received on the Outlaw was the CD up-sampling, and I am pretty sure it came from you:)
    What are you using for your connection? RCA, Optical, or COAX?
    Not to get a debate going, but... the Coax ON OUR PRE'S sounds best. I don't know if it is the digital to optical to optical to digital that is to blame.
    Ben
    F1nut Posts: 52,002
    There's your problem. CD's on a top notch player are generally excellent.
    Vinyl isn't all it's cracked up to be. I've heard plenty of it that made my ears bleed.
  • danger boy
    this is on my 2 ch only rig. Pioneer Elite amp, Sony ES playa, different CD", SDA 2B's with RDO tweeters... just was commenting about the harshness of digital audio. i bet they could warm up the sound a big without losing any dynamics.
    bass from the SDA 2B's is insane though. ;)
  • Danny Tse
    Danny Tse Posts: 5,206
    danger boy wrote: »
    It's called SACD. I'm not saying this is the ultimate digital experience, but when done right, SACD comes very close to analog and it's miles ahead of CD. It's quite hard to explain....it's not necessarily the higher resolution of the increased dynamic range....SACD just sounds more "natural". Most likely the increased sampling rate. Of course, not all SACD will sound excellent, but recordings such as Steely Dan's "Gaucho" SACD simply sounds amazing.
    Btw, I have no expensive components....just a pair of Grado SR60 headphones ($69.00) and a Sony DVP-NS500V SACD/CD/DVD player ($175.00).
  • Midnite Mick
    Midnite Mick Posts: 1,591
    The quality of the DAC is critical!
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • bikezappa
    bikezappa Posts: 2,463
    Why can't CD's sound more natural?
    By natureral I assume you mean it should sound like the real thing or sound like live music. The problem is that we rarely get to hear live music without the layer of microphones, amplfiers and speakers. So we really can't compare what our in home system sounds like to natural live music, beause we never or rarely hear live music.
    The first time I heard the Boston Symphony, BSO,I was shocked by the sound of the violins and the brass. The brass sounded harsh and it was not smooth.
    I think today you just play any thing you want any way you want to fit your needs because trying to replicate live music is just about impossible.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    I just bought the re-mastered Joshua Tree and I was very disappointed. It is very flat and lacking any sense of dynamics.
    I have found that a hand full of CD's that I could not listen to prior to upgrading my 2 channel amplification are now very listenable and all of my other favorite good sounding CD's sound even better. Morph the Cat sounds awesome but it would probably even sound good on my kids battery powered sing along CD player.
    I am also disappointed that some of my favorite artists CD's don't sound as good as they can or should.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • Early B.
    Early B. Posts: 7,900
    CDs, in general, aren't inherently harsh; it's the systems that make them sound that way.
    If your music sounds harsh, then you have to isolate the cause(s) of the harshness and change out components accordingly. Start with the source.
    "God grooves with tubes."
    VR3 Posts: 29,549
    I would say 10% of my CD's sound harsh...
    I can listen for hours on most anything
    Definitely isnt totally the CD's fault...
  • shadowofnight
    shadowofnight Posts: 2,735
    Lasareath wrote: »
    I have a 14 year old Sony ES player and it sounds amazing. It's warm and not harsh at all.
    I have a Sony C87ES from the early 90's as well...it sounds awesome to this day ( Dont use the selectable digital signal processing...just press the Flat button and its perfect )
    The first rule of Fight Club is you don't talk about Fight Club
