What are the best 2-channel beginner audiophile speakers
suppiluliumas
suppiluliumas Posts: 31
edited December 2007 in Speakers
I am undecided. These would be within my budget (eventually anyway) RTi6, Monitor 40, and r50. Does RTi make a big difference vs the Monitor or the R series to the beginner?
Post edited by suppiluliumas on
  • BaggedLancer
    BaggedLancer Posts: 6,371
    the "best" speakers is personal preference. Every speaker has it's ups and downs, just listen to them all and decide for yourself the "best".
  • ben62670
    ben62670 Posts: 15,969
    KEX pointed this site out to him. This IS Polk Audio on Ebay.
    http://stores.ebay.com/Polk-Audio-Direct_Home-Audio_W0QQcolZ4QQdirZ1QQfsubZ153926419QQftidZ2QQtZkm
    reposted
    "I just checked out the Ebay store, and those R30 are a steal.
    http://www.polkaudio.com/homeaudio/s...rstanding/r30/
    I have never heard them, but $100 BIN a pair
    Thats 400% off retail from Polk
    I would start another post if the R30s are to your taste. $140 with shipping anywhere US via FedEx ground is cheap!
    Silk tweeters"
    What do you guys think of the R30.
    I know the guy wants a Ferrari at Chevette prices, but I think he may do fairly well here.
    Ben
    Ben
  • suppiluliumas
    I know always comes down to personal preference, but the problem is that I can listen only to the monitor 40s at CC. They don't carry anything beyond the monitor series and currently do not have the r50s. No other stores carry Polk around here (Mpls), at least that I am aware of. I would like some opinions.
  • suppiluliumas
    ben62670 wrote: »
    I know I want Chevette prices but I am looking at something a bit more modest than a Ferrari... more like a Volvo or BMW. Something nice (not cheap, but neither gaudy). Well built and good performance at the lowest price is my aim.
    Regards,
    King of the Hittite Empire
  • ben62670
    beginner audiophile speakers, and monitors is an oxymoron. The monitor series is the bottom of the line speaker. It was designed for people on a budget that are into decent HT. I would not consider them beginner audiophile speakers at all, or even musical at all. The RTIs are a good compromise for HT, and casual music listening. The LSI's I would say are a great value in the HiFi market. If you go Monitors for music I can almost guaranty that you would not be satisfied. The RTI's have much nicer drivers than the monitors, and if you want to upgrade in the future monitors, and RTI's are not a good timber match. RTI's, and LSI's play together much nicer. Have you looked at the cherry R30's? Read any reviews?
    Ben
  • suppiluliumas
    I've looked at the r30s but the r50s are only $10 more each and have a second 6.5" driver. Are the r towers a good investment or would they grow old fast?
    heiney9 Posts: 25,447
    good performance .
    Regards,
    This is a very subjective subject. A little more discussion is needed and YOU really need to try and hear some different brands for yourself. What are you trying to accomplish, what kind of music do you listen to, what are you room dimensions and placement options, what typical volume will you listen at. Form over function or form = function or function over form, what have you owned in the past and what did and didn't you like about it?, etc., etc., etc.
    My suggestion start with a pair of Polk SDA CRS's. or a pair of LSi 9's. But that's more what I like, because I have no idea what your end goal is or preferences are.
  • suppiluliumas
    I want something that will perform well in a small/average living room (12x15 or so) or in a bedroom perhaps slightly smaller. I want the speakers to function as well as they can within the form of my room(s).
    I don't think that I can go any higher than RTi6... bookshelf is preferred.
  • ben62670
    I think the RTI6 book shelf would be a great start;)
    I have listened to a bunch of speakers under a $1000 over the years, some lots more, and the RTI's are a real good bang for the buck speaker.
    Ben
    You seem to be looking at the Monitor series and the RTi series, the RTi is a slightly better line as they use better cabinets and drivers. With the RTiA line coming out replacing the RTi line you should be able to get some killer deals on closeouts.
    Also remember to set aside a $150-200 for a nice sturdy set of speaker stands if you go with a bookshelf model. Preferably stand that are fillable with sand or shot are the best.
  • suppiluliumas
    As for its use, I will them for movies when I watch them but more for music. I'm a classical fan (it's actually concert music... classical is just one era... probably the wrong place talk about that) and little of a lot of things, e.g. Neil Diamond, Johnny Cash, U2, Instrumental, and (I'm not afraid to admit it) ABBA (I can't do the first B backwards), some other older artists, very few contemporary.
  • suppiluliumas
    Can I actually put a bookshelf on a bookshelf/shelf?
  • AndyGwis
    AndyGwis Posts: 3,655
    Get some used LSi7s and a decent integrated amp or stereo receiver. HK 3480 and LSi7s could be had for like $400 - $450 combined if you shop around.
    Or, get on craigslist locally and check out what speakers they have available. I've found some great stuff locally on CL before.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • stangjason
    stangjason Posts: 341
    I would look out for deals on the RTi4, RTi6, and RTi8 because they are fairly reasonable on several sights. Keep a watch out on frys.com, onecall.com, crutchfield, and ebay for some good deals on them.
    I really think you'd be happy any of those but my only experience is with what I've got: 2 pair of RTi8, fxi3, and CSi5. If the RTi8 or fxi3 are an indicator of how good the rti4 or rti6 sound then you won't be disappointed.
    Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
  • suppiluliumas
    Thanks guys. I would only go LSi if they $300 for the pair. I know that asking for an Aston Martin for the price of a Camry but that's my budget. probably look for RTi4/6
    Thanks again,
  • capecodder
    capecodder Posts: 613
    Thanks again,
    I would second heiny9's reference to the CRS (or CRS+ even more) which might be had used for $300 if you could find a pair. They are my main speakers, I love them, and they have the SDA feature which is highly regarded around these parts. (You would also have a cool factor to impress your friends and neighbors since no one else will probably have a pair:cool:)
    Personally, I would buy a clean pair of used far before I would buy entry level grades of any speaker for anything close to retail. But then all my equipment is second hand at pennies on the dollar. I will also admit to having never heard the RTi series.
    Just saw your other post about speakers for classical listening. The CRS line produces a fabulous soundstage and should be very good for those purposes as well.
  • suppiluliumas
    Where is the best place to look for CRS online/in person?
  • stangjason
    I should have mentioned before buying my RTi series stuff for six months I had some R series speakers (CSR, R300, and R150). I loved the sound of the R series speakers except I felt something was missing so when I got my RTi series I realized that the R series though as good sounding as they were they were just too small for my room and didn't give me the same soundstage as the RTi series did.
  • capecodder
    Sorry for assuming something you probably don't know. The CRS speakers are vintage from the mid-late '80's and sold for around $900 back then so you know they were the real deal. They are the "bookshelf" version of the SDA line although they work best on stands. (Mine are in the "shelf" for WAF reasons and sound great). No longer made and can only be got used. They come up on eBay from time to time and I believe a few members here may have a set for sale. Price I don't know.
    Go to polksda.com and look at the pics of the various models to familiarize yourself with the vintage lines. Not to steer you too far away but the vintage Model 7 speakers are also very well received here as well. Can frequently be had for $100 to $150. I now have 3 pairs....
  • suppiluliumas
    Thanks, I'll keep my eyes open for the older sets. Any guidelines about buying old/used sets?
  • capecodder
    Obviously visual/physical condition and try to audition if possible. Get a sense whether the owner is an audio enthusiest or a "crank em up at the frat party animal".
  • suppiluliumas
    Know any trusted sellers?
  • Midnite Mick
    Midnite Mick Posts: 1,591
    delete.....just saw the budget
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • capecodder
    If you post in the Vintage section and ask around you may find some. You will probably get some good feedback as to who is trustworthy. Most are, especially with any track record.
    As tactfully as I can be... don't start 10 threads or so at the same time and swamp the forum with 100 questions. Take your time, digest the info, do a little web searching and you will be fine. The vultures won't descend quite as fast to pick the flesh from a newbie.
    Welcome to the forum btw:).
  • McLoki
    McLoki Posts: 5,231
    For a good starter speaker on a budget - this is my choice hands down....
    On Ebay...
    Another e-bay
    On Audiogon
    While they are nowhere near Gods gift to two channel listening, but they will make listening to music fun and may be some of the best you find for under $200. (much better than the current R or Monitor series in my opinion.)
    Michael
  • Yashu
    Yashu Posts: 772
    PSB Alpha B1s all the way. There is no way to get more for your money.
  • rskarvan
    rskarvan Posts: 2,374
    Perhaps a set of Polk RT25i's. Very highly regarded bookshelf speaker. Inexpensive too.
    Ebay Auction Item No. 190185010843
    mhardy6647 Posts: 35,050
    Pair of Monitor 7As would be quite high on my list of "beginner audiophile speakers"...
  • Shizelbs
    Shizelbs Posts: 7,433
    Scour audiogon. That and craigslist. Read and read and read and educate yourself to find the best deal you just can't help resist. For example, I have a pair of speakers I snagged for $400 that I doubt I'd want to replace with anything costing several times more. There are deals out there, you just have to be ready for them and know what they look like.
  • Shizelbs
    As they are on mine.
