Onkyo+Lsi 15's
volcom1981
Hey guys, new to the thread and was just wondering if the Onkyo TX-NR 1000 would be adequate power for lsi 15's? It produces 150 watts per channel @ 8 ohms to all channels. I have 2 sets of lsi 15's running front and rear. Thanks
Post edited by volcom1981 on
Welcome Volcom,
Do a search on Lsi's used with receivers, this topic was covered a lot over the years. Generally, the Lsi's are 4 ohm and this can be taxing on the amps in AVR's. A separate amp made to run at 4 ohms is the best solution. If used at low volume levels in a small room, you may be able to get away with the Onkyo, but I do not think you bought 2 sets of Lsi15's to play at low levels. Check out the used market like audiogon.com for Outlaw amps, they usually fit the bill.
Venom -
Welcome to CP Volcom,
The onkyo will be able to drive them, but to get best out of your LSis you need to add an external amp. In Addition to Outlaw mentioned above, you can look at Parasound, Rotel and Adcom also.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
All of the above are good. Carver is another amp to look at.
engtazengtaz
thanks for all the advice guys! This is my current system, sounds pretty decent so far, but will require some tweaking. Might not be the best thing to mix lsi series and rti but unfortunately money doesnt grow on the trees round here.
Onkyo Txnr-1000
2 sets lsi 15's front and rears
rti6 surround back
csi5 center
Velodyne dps 12 sub -
The RTi's should be just fine for surrounds. Others might have better experience with the CSi5 than me, but my recommendation would be to get the LSiC when money allows in order to match the front soundstage better. I have the LSiC and I think it's a fantastic center.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
volcom1981 wrote: »thanks for all the advice guys! This is my current system, sounds pretty decent so far, but will require some tweaking. Might not be the best thing to mix lsi series and rti but unfortunately money doesnt grow on the trees round here.
Onkyo Txnr-1000
rti6 surround back
csi5 center
Velodyne dps 12 sub
Hello, about a year ago I added an Emotiva LPA-1 amp to my setup of LSI15, LSI/C and LSI/FX. The improvement in sound an quality of the amp is impressive for the price. Right now they are on-sale. Good luck.
http://www.emotiva.com/
Mick88
