Please Help...Noise from front speakers.
sudhakar.sv
Hi All
Please help
In my car i have polk audio rear speakers and front speakers i have put boston components. recently i connected audison 5 channel amp. I have not connected sub woofer yet.
When I start my engine i get this sparking noise from my front speakers.
I tried connecting noise filters but it didn't help
When i switch on the AC the noise increases.
When i use the horn then the noise power also increases.
When i remove the antena connection the noise reduces but it does not stop it is still present.
Also i read in one of the posts
"check and make sure your remote wire is not pinched. i had the damndest time figuring out the remote wire will cause noise if the insulation is rubbed thin in a spot"
Can anyone please explain what this means.
Please help
Post edited by sudhakar.sv on
What type of automobile do you have? Sounds like you have some grounding problems. When you removed the antenna you actually removed a ground source from the head unit. Make sure your amplifier is grounded properly. Use a nut and bolt and make sure to grind all the paint off. Also check your head units ground sounds like there might be a problem there. I ran a 1/0 ground from my battery to my frame then ran a 1/0 ground from the frame to my amps. I have done this on my past three trucks and have never had a noise problem. Audison amps are usually clean and I have never had noise an issue with these amplifiers. Sounds like a install issue.
