Subwoofer grille rods
Drowsy09
Does anybody know where i can get them cheaper than these?
http://www.crutchfield.com/App/Product/Item/Main.aspx?showAll=Y&g=742&i=136SGR12W7&tp=2054
Ive been searching high and low and this is the only place i can find them. But $60!
Post edited by Drowsy09 on
go to a home depot and get a few chrome towel racks
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
www.partsexpress.com has some similar.
What about something like this?
I believe that I paid under $20 bucks for it.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Actually it was $9 bucks + shipping on ROE. Look under fabrication....
http://store.realmofexcursion.com/Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
there are other ones on ebay, but those are almost 13 DLS + Shipping.
http://cgi.ebay.com/HEAVY-DUTY-12-SUBWOOFER-GRILL-SUB-SPEAKER-COVER-GRILLE_W0QQitemZ120198936945QQihZ002QQcategoryZ67773QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
actually im going to buy one.Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
KnuKonceptz MKS Kable -
Kinetic - Before you go there - they are cheaper here.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-442 -
1996blackmax wrote: »Actually it was $9 bucks + shipping on ROE. Look under fabrication....
Woow the power cable is cheap and im going to need some, is it a good quality cable?
i need some 2 GA, and some 4 GA and a distribution block,Z
Polk Audio SR 6500
G35
thanks Drowsy thats cheap tooZ
Polk Audio SR 6500
G35
I actually use these guys for all my wiring......
http://www.knukonceptz.com/index.cfmAlpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
ive seen it here, and looks better quality than the other one.
i will take another lookZ
Polk Audio SR 6500
G35
