Is my LsiC broken?
Squeak
Squeak Posts: 2
edited December 2007 in Speakers
I have had these speakers for about 4 years, and recently moved them down to a new room in the basement. My center speaker is much lower then before and I am starting to notice that sounds only comes out of the larger right baffle, and nothing comes out of the larger left baffle.
Is this normal, or should sound be coming out of both sides of the speaker? The same thing happens when I listen to 5.1 content as well as calibrate the decibel level of the speaker via by receiver's configuration.
Any thoughts? Thanks
Post edited by Squeak on
  • beardog03
    beardog03 Posts: 5,550
    Do a search on this speak, I believe it`s a cascading crossover type, and they sound isn`t always commig out of both
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Squeak
    Squeak Posts: 2
    Thanks. Good to know. I am not noticing any sounds from the left driver, but I could just not be picking up the bass.
    Thanks again.
  • beardog03
    does it give you anything a louder volumes ?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • john22614
    john22614 Posts: 214
    Also, if you set it to large (just as a test) you should notice significant bass sound and driver movement. I thought mine was broken too.....but it's just the way its designed.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
  • BaggedLancer
    BaggedLancer Posts: 6,371
    You could always flip it over so you get sound out of the left one.... :D. Kidding.
    I've read stories on the forum here of people moving speakers to new homes and they stop working, for various reasons, one being that a wire may have fallen off the woofer or crossover. If what other suggested doesn't work, I suggest taking the 2 minutes to unscrew the woofer and double check all the wires are attached. Never know, that little trip down the stairs might have just jingled it loose.
    Good luck, report back if you find anything.
  • beardog03
    also a good idea...
    won`t take but a minute to check..
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • margate21
    margate21 Posts: 105
    i thought something was wrong with my lsic and lsifx when i first bought them because sound only came out of one side. i called polk technology and he told me that was the way it should be. one side is a woofer and one sound.
    lsi 15's, lsi c, lsi f/x
    onkyo 805
    sunfire tga 5200
    toshiba - xa2
    panasonic bd30
    sony kdl40v2500
    svs sb12+
  • beardog03
    are you sill having problems, or did this clear things up for you ?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
