Pics of Bucks SDA 1.2TL's
buckfishing
I've never been on a sight like this so I'm not familiar with many of the ways to re-post, reply, and so on. I'll do my best. I have taken some pics so you guys came positively ID my speakers. From there I'm sure I can start getting down to business. I appreciate all your patience and help!!
Buck
P.S. Although John Candy was a great actor and comedian, fortunaltly there is no resemblance.
Post edited by buckfishing on
a close up of the tweeters would help, they look like the SL3000's, if so, you may have the 1.2tl's, which are the latest model.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
They definately look like SL3000's. I would have to say 1.2tl's.
And from the small pics they look to be in AWESOME shape for a 100 bones
The first rule of Fight Club is you don't talk about Fight Club -
My 1.2TLs are in the 6470 range and were bought in late 1989.
pretty sure mine say tl after the 1.2,I thought it was fairly amusing also. The Polk Ogre doesn't always get 'it'
in the serial #I thought it was fairly amusing also. The Polk Ogre doesn't always get 'it'
sorry just checked mine the right channel does not say tl but
the left speaker says 1.2tl in the serial #I thought it was fairly amusing also. The Polk Ogre doesn't always get 'it' -
Mine say TL on both speakers in the serial number. I've posted a picture of my SL 3000 when I sold them. You will see what I mean by brassy dome.
Mine don't say TL on them anywhere, either.
Hey Mister Computer Hater where are you?
Serial numbers on mine are 6387 and 6400. Does not say TL.SDA SRS 2.3TL's
SDA 2B TL's -
Listening to pure musical bliss.
Anyway, Polk routinely used leftover labels, etc. and it's a known fact that not all SDA SRS 1.2TL's have the TL on the S/N label. One way to ID them is to check the number on the crossover, the TL is BE2000-C and the 1.2 is BE2000-B. Another way is to look at the crossover plate, the 1.2 TL has one bolt in the middle while the 1.2 has 5.
Adding to the confusion, Polk offered an upgrade kit for the 1.2 converting it to a TL, but I do not beleive a new crossover plate was part of the package.Political Correctness'.........defined
President of Club Polk -
Didn't some of the later 1.2s use a one-bolt plate?
My 1.2TLs are 6466 and 6472, and no TL markings.
