First Time Buying An Amp... Help Me Out!
KS740
Ok so i just bought a pair of 6x9 Polk Speakers (db691 to be exact) and I need to find an amp that will give it that top quality sound.
Here are some of the spec's to the speakers:
Overall Frequency Response 35Hz-22kHz
Nominal Impedance 4 ohms
Power Handling (continuous) 100 w
Power Handling (peak) 300 w
Efficiency 93 dB
i really just need a general direction on what type of amp get, but i love to hear some suggestions from you guys. Post if you still need more info.
thanks o' ton
Efficiency 93 dB
thanks o' ton
Post edited by KS740 on
Post in the car audio section for a decent response. Based on my experience with car audio which is average, I would suggest a 4 channel to run the inside speakers and a mono amp to run any subs. Some of my favorites and that I have used PPI, Fosgate, Alpine, JL Audio, Soundstream. Theres so much more out there now its hard to choose. I heard Memphis is good, though I havent heard one.Shoot the jumper.....................BALLIN.............!!!!!
Car Audio Section meaning the Receiver?
What Sherardp is saying is...ask you question here http://www.polkaudio.com/forums/forumdisplay.php?f=5"she had the body of Venus, with arms."
Thread moved.
A C300.2 would be a great match for your speakers. That being said, do you plan on adding any other speakers, or a subwoofer? If so, there are other multi channel amp options that you might consider, depending on your 'end' goal for your system.
http://www.polkaudio.com/caraudio/products/amps/c300_2/
Welcome to the boards, and thanks for choosing Polk Audio!
Cheers,
Well as far as the rest of the system goes I do have (2) 6.5in speakers in the front but I wasnt looking to put an amp thru to them, Instead ether 2 10in subs or a 1 12in sub in my trunk.
what can you make with that?
any ideas?
I'm such a noob to this stuff lol -
You could add a C500.1 to drive the two 10's or one 12 - or just get the C400.4, which can run in 2, 3, or 4 channel mode and drive your DB series + a sub from a single amplifier.
Cheers,
You know what... I'm gonna go with the C400.4 on this one, seems like a better way of doing it.
wow thanks a ton for this RuSs you really saved me a lot of time on this.
have a great holiday! -
Here is a good place to shop around.
Browse thru these and find the ones you like best. You need something in the 75-100 watts per channel RMS for best results.
http://www.crutchfield.com/App/Product/Group/ProductMenu.aspx?g=120&c=3&tp=115&avf=Npolkaudio sound quality competitor since 2005
The 400 does offer a lot of flexiblity, and a great choice if you ask me.
Keep us posted on your install, and right back at ya with the holiday wishes.
Cheers,
