bi-amping
928man
928man Posts: 71
edited December 2007 in 2 Channel Audio
I recently obtained a pair of speakers that are bi-wireable. Does that mean they are they bi-ampable?
If you bi-amp do you have a pre-amp with dual outputs or is there some sort of splitter cable used for standard 2 channel pre-amps?
Would also need two complete sets of speaker cables?
What is the benefit of bi-amping? Do you use a specific type of amp for the highs and then a different one for the lows or should you use matching amps?
Post edited by 928man on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    928man wrote: »
    Yes
    Yes, dual output, or you can use a y-splitter from a single set of outputs.
    Yes, some people even use a different type / brand of cable for the highs / lows.
    In a nutshell, further use of separates. A dedicted amp for the highs frees up amplifier power for the low transients for one example. Some people use matching amps, a lot of people like to mix it up. If you do mix it up, you might want to pay attention the impedance of the inputs on the amps, so the gain is matched properly.
    Cheers,
    Russ
  • hearingimpared
    hearingimpared Posts: 21,136
    Just to follow-up on ^^^^^ Adcom 565s on the low and a Parasound HCA 1000A on the highs on my 1.2 TLs sounded awesome. So I believe you may get away with the combination of those two companies other amps when biamp'g.
  • 928man
    928man Posts: 71
    Wow, that was a great answer Russman! Sounds expensive to do it right
    and also fun to try different amps on the top and bottom. Do you lose a lot of sound quality using a single output preamp and a splitter cable to the two amps? What exactly would you call that splitter cable?
  • jdhdiggs
    jdhdiggs Posts: 4,305
    You may also want to look into some line level filters for the inputs to the amps. There's no reason your "highs" amp should see the low frequency signal and vice versa.... This allows you to use a really nice flea tube amp for your highs safely.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • TroyD
    TroyD Posts: 13,124
    If you are new to all this, not to be a spoil sport, I'd approach this with caution. I say this because, particularly with different amps, the more variables in the equation....the greater the opportunity to dick things up. I, for one, am not a fan of using different amps unless because of the different gain involved.
    BDT
  • ohskigod
    ohskigod Posts: 6,505
    I currently biamp my AR9's with fantastic results, worth a try, but while your trying things out, just be careful. I use same amps, figured it would be easier, but have heard biamping with different amps sound pretty damn good, Joe's rig being a good example.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • TroyD
    TroyD Posts: 13,124
    Lou,
    Are your Amazings just gathering dust or what, bro?
    BDT
  • hearingimpared
    I really didn't think that using the Y splitters on my biamp'd setup revealed any SQ loss. YMMV however.
    There is a fellow member that can make you some very, very good Y splitters. If you wish to know who it is please PM me.
    PS: I had mine customed made by Frank at Signal Cable.
  • 928man
    928man Posts: 71
    Exactly where do the line level filters go? I understand they go between the preamp and the amps but where do they attach and where is a good place to shop such items?
  • Systems
    Systems Posts: 14,873
    TroyD wrote: »
    BDT
    What Troy said. Unless the amps have identical gains you will end up with a frequency response imbalance.
    Testing
    Testing
    Testing
    treitz3 Posts: 19,952
    For me, vertical Bi-amping is what makes my ears happy. Bi-amping, though it can be expensive, it can be a lot of fun as well.
