Polk FXi3
Art VanDelay 30
Art VanDelay 30 Posts: 14
edited December 2007 in Speakers
I was curious if you could place these at ear level on a bookshelf or will that lower the surround effect? If the speaker is angled up would that help?
Post edited by Art VanDelay 30 on
  • hearingimpared
    hearingimpared Posts: 21,136
    I don't know the answer to your questions but I wanted to tell you I love your screen name.
  • pearsall001
    pearsall001 Posts: 5,093
    Best placement is approx. 2' above the seated position if that's possible. If that's not possible, do the best you can as your room will allow. Tilting them upwards will certainly help.
