Ground Loop Isolator
daboyz
daboyz Posts: 5,207
edited December 2007 in Wanted (WTB) Classifieds
Hooked up my Adcom GFA 7400 and got a nice little hum outta my speaks.:( I disconnected the TV cable and poof it's gone. Now I need an isolator. Any out there or suggestions?
Thanks, Dave
Post edited by daboyz on
  • Systems
    Systems Posts: 14,873
    Jenson ISO MAX has a solution for that the VRD 1FF.http://www.jensen-transformers.com/iso_vid.html Or if you are handy with a soldering iron you can make an adapter with a couple of capacitors.
    Testing
    Testing
    Testing
  • MillerLiteScott
    MillerLiteScott Posts: 2,561
    If it is a three prong power cord try one of those 99 cent cheater plugs and if that eliminates the hum break the third prong off of your power cord and wala no hum.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • Systems
    That third prong is there for a reason ,I would look to a better solution than defeating the safety ground.
    Testing
    Testing
    Testing
  • MillerLiteScott
    GV#27 you are right. I should have included a little note that YMMV and it may be best as a temporary fix while a more permanent solution could be found.
    Sorry for the bad info.
    Scott
  • Systems
    I should have included a little note that YMMV and it may best as a temporary fix while a more permanent solution could be found.
    Scott
    Yeh Scott that is an oft used suggestion that may solve the problem but there are other ways.
    Testing
    Testing
    Testing
  • PSOVLSK
    PSOVLSK Posts: 5,216
    Radio Shack has one for about $20. I hooked that up and connected a speaker wire from the chassis of my amp to the chassis of my AVR.
  • daboyz
    daboyz Posts: 5,207
    I bought one from PartsExpress for $10 shipped. Hopefully it does the trick.
  • PSOVLSK
    Wish I would have bought there.
    As I mentioned in my previous post, I also took speaker wire and connected it from the chassis of my amp to the chassis of my AVR. Did the trick for me.
  • daboyz
    daboyz Posts: 5,207
    daboyz wrote: »
    Worked beautifully!!!!:D
  • phipiper10
    phipiper10 Posts: 955
    Like an idiot I bought one the other day and then realized, I should plug the cable into the montster HTS conditioner I already have. I did that and problem solved......
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • michaeljhsda2
    michaeljhsda2 Posts: 2,185
    Did you buy the Dayton VIT-1 Isolation Transformer, Part Number 180-075, for $8.40 at Parts Express? I did and it eliminated the hum. Hope it works for you.
    Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
