Help; Polk 404 sounds very different
64met
Guys,
I upgraded e/thing recently except my sub. Now out of the clear blue while watching a movie my 404 sounds like "glass is breaking" meaning kinda like NO bass; but just rattled sound?? I don't know if this is a result of my upgrade or what? I tried re-adjusting the settings; no luck.
My new speakers... fxi3; rti10 and csi5.
Any ideas/suggestions?
Dedicated HT: JVC RS-2 Proj; Carada 104' fixed screen; Yamaha RXZ-7; Outlaw 7 X 200; Toshiba HDXA2; Blu Ray Panasonic 30; Polk Rti10's;
Csi5; Fxi3 and Outlaw LFM1X Sub; RTi Universal RC
Post edited by 64met on
You need to give up more info when asking these questions.Are you useing speaker level inputs? What is the crossover set to? Plugged in to the LFE on the receiver?Most of your problems are going to be in the setup menu of your AVR.How do you have everything wired up?HT SYSTEM-
lsi 9's -
I had the same problem w/ my 303, just before it poofed-DON'T FREAK OUT!
Try reconfiguring your hook-ups, crossover, plugging the sub into another outlet/ power source. When mine blew, I lost my pc at the same time, so I don't know which component caused it.
Good luckI refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Great, thats all I need after the boss gave me clearance on the recent upgrades! I wll however, follow your suggestions and see what happens.
ThXSDedicated HT: JVC RS-2 Proj; Carada 104' fixed screen; Yamaha RXZ-7; Outlaw 7 X 200; Toshiba HDXA2; Blu Ray Panasonic 30; Polk Rti10's;
