Help for biasing Jolida AMP
franco_rome
franco_rome Posts: 3
edited December 2007 in 2 Channel Audio
Hi all,
I have to change the 6550 tubes of my Jolida 502B with a KT88 or 6550 quad and I'm in trouble.
First. I haven't the user manual, but searching in this forum I found something that could help me: using a Voltmeter I should stich the negative probe in the central hole, of five ones, which are positioned between the valves and the transormer, than the red (positive) probe in the hole numbered according to the tube I want to bias.
Turn the relative screw until the correct value is on the display of the voltmeter. Is this procedure correct?
Second. Which value af tension must I obtain? Do I have to use the value present on the Valve sheet or a default value suggested for the amp?
Third. Could someone suggest a fine (open and detailed sounding) brand of KT88 or 6550 tubes to look for?
Thanks in advance.
Franco
Post edited by franco_rome on
