Can Not Find Out Server????
nikolas812
nikolas812 Posts: 2,915
edited December 2007 in Electronics
"Can not find out server" Is the message I get when I try to update my toshiba hd-a2 dvd player. When it starts downloading the update it displays 1/40 2/40 and so on. When it gets to 40/40. It comes back with the message can not find out server. Does anybody no what this means. I thought it might be something on toshibas end. So I waited a week or two before trying it again and it still gives the same message. I don't have a clue. Please help.
Post edited by nikolas812 on
  • Systems
    Systems Posts: 14,872
    Look in your network settings and test your internet connection. If thats ok, check the time on the unit. Activate the setting for the unit to pull its time off the network. My A30 would not update untill I did that, the unit has to have its time set right.
    Testing
    Testing
    Testing
  • nikolas812
    I'll try it. Thanks!
  • nikolas812
    Well I tryed it with no luck.:( I don't think the toshiba is picking up my ip address automatically. It says if it doesn't pick it automatically to do it manually. But I think that is more than I want to fool with. Considering I don't know much about computers. Theres a lot that needs to be put into the dvd player when done manually. IP address ,Sub MAsk Default Gateway, DNS server, and Proxy settings. I don't know what any of this is.:o If someone could help that would be great. I would really like to be able to use the ethernet feature on my dvd player. But it's starting to look like I am going to have to find a update disk. If anyone could help I would appreciate it.
  • avguytx
    avguytx Posts: 1,628
    Mine did that so I just burned the ISO file to a CD and it worked fine. Here is a thread of what it involved. Shawn474 was a big help in me getting it done.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • PolkThug
    PolkThug Posts: 7,532
  • malikarshad
    malikarshad Posts: 527
    I had to try few times to get it working.
    I kept on trying and i think on the 3rd or the 4th try it was able to download the firmware.
    Neverthless the firmware update did not do anything good to my A2.
    Also I forgot to mention that I read somewhere on AVSForum to "Initalize" it before the update. But I did not initalize it as I read it after the fact.
    Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
    PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
    Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
    Sub - JTR Captivator S2 (Dual 18")
    Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
    Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
  • millerman 3732
    millerman 3732 Posts: 1,488
    nikolas812 wrote: »
    Here's what you need to do. first unplug both the your modem and your player for about a minute. then plug them both back up, your modem should be back up and running by the time the player is booted up, then go into the setup menu and then go into the Ethernet set up turn on DHCP, all the numbers should filled in, and then turn on DNS and confirm everything, you shouldn't have to mess with any of the other settings, if the numbers stay filled it then you should be good to go and just go ahead and update the player, if the numbers all go blank you need to repeat the process, but it should work.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • nikolas812
    Thanks for all of your responses but I have tryed all of that. I initialized, I tyred downloading SEVERAL times. I even tryed to burn the disc online.After I burned the disc and tryed it the dvd player didn't recognize it. I tryed that several times also. But none of it matters. I called toshiba today and they said a disc should be here in 7-10 days.:)
  • Sherardp
    Sherardp Posts: 8,038
    enable DNS as well. Mine was doing this also.
  • shawn474
    shawn474 Posts: 3,052
    Download the update to your hard drive. Get a new disc and follow the instructions below:
    After you burn the file to your hard drive, use this program to extract the file:
    http://www.ntfs.com/iso-burning.htm
    On the left hand side of the top of the page, select isoburner.exe and it will finalize the disc.
    Pop the disc in and it will ask you if you want to update. Press "YES" and after about 25 minutes, you are updated.
    This has worked for me and for everyone that I know that was having trouble.
    Shawn
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • nikolas812
    Shawn
    Thanks man! That was just what I needed. I did exacttly what you said to do and it worked fine.:D
