R10's vs Monitor 30's
I have a setup with the R10's as my fronts in a small room with the CS1 as the center with a Yamaha rx-v659. Would it be worth it to be step up to the Monitor 30's for the sole purpose of voice/timbre matching? As far as i can tell the R10s and the Monitor 30's have similar specs with only the tweeter being 1/4 of an inch bigger in the 30's. The lower and upper -3dB limit is also slightly different. Thanks.
Post edited by Danklin24 on
anyone??
Do they sound good to you? The only reason I ask, is, I've upgraded my system 3x in two yrs.
I don't know what the r10's sound like, but I do know the monitor 30's are sweet for the money- I've got 4 of the T20EB's- which are the monitor 30 but with Tweeter monicker.
If there's a Tweeter close to you, You can probably pick some up for $130/pr.
Check out their website, look under clearance and see if there are any listed
Again, T20EB is the Tweeter moniker for monito 30's
Good luckI refuse to argue with idiots, because people can't tell the DIFFERENCE! -
I'm not sure if the monitor 30's would sound better or not. I'm asking because i know the 30's are the recommended fronts to match the CS1 center speaker. The R10's do sound pretty good but im nowhere near an audiophile and wondered if maybe i wasnt listening for something i should be and the 30's should sound better if i had them. I guess ill keep my R10's for now. I could get the 30's and send back if i dont notice any dramatic difference.
