Monitor 10 score (I think)
johnny_fever
johnny_fever Posts: 19
edited December 2007 in Speakers
Hi,
I think these are Mon 10's. Funny thing Is the size is Different from specs on this site. Specs say 28" H 15" W & 12" D. Mine are 28" H 16"w & 11" D. The seller posted them as large Polk speakers but was unsure of model. I can't find any model #'s or markings. I pulled the crossover out and I could see the Part # on the mids (MW6600X) Date on sp 2/23/84 Date on Crossover 2/10/84. I will hook them up tonight and give them a test Drive. Thanks Rick
Post edited by johnny_fever on
  • avguytx
    avguytx Posts: 1,628
    Could be the Monitor 10A which falls into that range being that the date on the crossover is 1984 per the Vintage Speakers site. Or, it could be a 1984/85 model 10B if those are SL1000's in there. Not sure what the MW6600X's are unless they were changed out. What model tweeters are in them? Did you pull them, too?
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • Face
    Face Posts: 14,340
    They appear to be SL1000's. As per http://www.polkaudio.com/forums/showthread.php?t=38755 the crossovers appear to be the same as the original M10.
  • johnny_fever
    Yes these are the SL-1000 Tweets. And both of them are blown. I didn't test the speakers at the guys house because The voice coils moved free and
    I thought how could I go wrong for $40. Thanks for taking the time to respond. Rick
  • jtgranby
    jtgranby Posts: 887
    Check the fuses.
    Jim
  • johnny_fever
    Hi jtgranby,
    The fuse tested OK. I also cleaned the fuse holder with a small wire brush.
    I will pull the speaker out again & test. Thanks. Later Rick
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    You can get replacement tweeters from Polk, club members get a little discount.
    or
    Search the web, ebay and so on.
    RT1
